![]() | Home > Technical (L322) > TD6 Service / now wont start |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
Did a service on my TD6. Oil, Fuel, Air, filters & pollen filter. Flattened battery trying to start it. Recharged battery. Every thing worked O'k before service ???
Thanks Meerbusch. But have flattened battery twice now. Doesn't seem to want to prime properly for some reason. Will have another go tomorrow.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Maybe there is a blockage in the new filter? Try putting the old filter back on. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Always fill the replacement filter with clean diesel before fitting and attempting to start! Otherwise you put a huge strain on not only your battery but your starter motor and the rest of the electrical systems...
Thanks Craig .
I've never had to do that with a diesel before Craig, and with the FF both times its been fine.
Have blown through filter both ways. So I dont think there is a blockage.
Fill the filter to the brim with fresh diesel before trying to start |
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
if you can take the feed to the filter off and no diesel comes out when you turn the ignition on then it wont make a difference if he fills the filter or not, the system needs to register low pressure at the filter head to start. just because the low pressure pumps are running doesnt mean they are pumping, start by removing the feed to the low pressure pump infront of the rear wheel and turning the ignition on to see if diesel flows. if it does the problem is with the secondary pump, if it doesnt the problem is the intank pump. time to get dirty, |
All go now. |
