![]() | Home > Maintenance & Mods (L322) > coolant cap 4.4 v8 engine |
| Marko Member Since: 21 Jul 2012 Location: Perth Posts: 4
Yo yo daveo thanks for asking about Sarah ,the car is all good but gets red hot when I blast it just seeing any one has some ideas marko |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
marko, go and get that sniffer test done, that will tell you if you have head gasket is giving you any problems. V8 facelift Range Rover Autobiography 22" wheels.
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Marko has the car only just stared playing up? I would change your thermostat as well. That sounds dead to me. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Thanks guys I'll send for one ps I've drove the car all week sensibly and constantly around 100 kz all gd only when I excerlerate fast through the gears she goes to red then half a min drops back to normal cheers marko |
Marko have you had a look what temp your running? If you use the hidden menus option/list 7 is for the temp. If you drive sensibly you can get an idea of the temp and what's going on. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
No ,I wouldn't no wot or y I would look at running temp sounds a bit teckie pps now wen I start car she runs lumpy as if she needed the choke pulled out ? |
Might not mean much to you but a few numbers would help us here. It could be a case your gauge is goosed. Anything is possible with these cars. Use the wiki for a how to on how to access the hidden menus. Worth it even just to know how to do it. Repeatedly overheating the engine can't be a good thing I would have thought [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| All times are GMT |
