![]() | Home > Technical (L322) > Violent wheel wobble - anyone cured this? |
| highfellzippy Member Since: 20 Aug 2011 Location: Yorkshire Posts: 153
swap the wheels with someone
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
can't see it being the diff........... i got more vibration stationary in D after the recall swap was done......
| daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201
I had a similar wobble between 75 and 85, it turned out one of the REAR tyres was |
I was going to ask why the mechanic went to Halfords to balance them..... |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
I don't like the sound of a LOT of balance weights added to wheels.
| nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233
Thanks for the replies so far chaps - the new wheels are genuine LR, with logo and serial numbers cast into the metal. Probably the next thing would be to get new tyres instead of the Continentals, and get all the bushes replaced after that, since my mechanic was happy that there was no significant wear.
Just one further thought, all your wheels nuts are tight I assume. |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
I had the same symptoms. Driving at about 50+ if I changed direction I got bad wheel/steering shake. The worst was long sweeping corners on motorways.. In the end it was the ball joint on a lower control arm. I replaced both myself, there are photo guides on this site.. Total cost about £50, and no more wobble. Previously..
I'm liking the sound of that - my wobble only happens with just a little left turn of the wheel, and disappears on straightening up and is exactly the same - on long sweeping motorway curves..
| Stocky Member Since: 13 Oct 2009 Location: New Forest Posts: 142
Had exactly your symptoms for a while now. Checked wheel balancing three times and used spare on OSF ( where I thought prob was). Always the same slight left turn at 65+ and big wheel wobble just like a faulty shopping trolley!
Thanks for that Stocky - I was driving today and the logic of it being worn bushes makes sense - the wobble is only with small steering deflections, whereas bigger inputs cancel the wobble - I guess small steering changes allows the worn bush/link/ball joint to be under less tension and so move about more. I've got some parts on the way tomorrow, but I now want to replace all the ball joints and the upper control arm bush as well, just to make sure. |
Yes it was just slight turns left, go tighter and it disappeared. |
Right - had the drop links and front control arms replaced today, and I've just come back from a test drive down the motorway, and.....IT'S GONE!!!!!! |
