![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
updated list of functions..
| PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153
Hi Guys
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528
Thanks Patrick
| T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936
In reference to the EAS motorway, are you able to change the speed the m/way height is activated at? At the moment i think mine changes at 100mph.
| PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877
100mph |
| DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425
+1 for being able to change the motorway height activation speed. 160km [100mph] is far to high. |
| duka Member Since: 11 Jan 2011 Location: uk Posts: 147
folks, I'm trying to clear faults which are picked-up when scanning, following the instructions, but can't seem to clear any faults - what am i doing wrong?? |
duka, firstly make sure you have the latest firmware [v2.17] , if so you select 'read' and then the ecu to read any faults ...the same with clearing faults , select clear and then the ecu.. ... - .- -.
| nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233
Is there a setting to keep the windscreen wipers going when returning to tha car? - i.e. if you leave the wiper switch on when you get out of the car, and then come back, drive away, I would expect the wipers to resume, but I have to switch them off and on again. A minor point, but it's annoying after using several cars that have this setting.
the reason the wipers need to be re-activated is a safety one ..on cold days the wipers might stick to the screen so having them switch on with the ignition might rip the rubbers off or you might scratch the screen if no washer fluid is sprayed on....
I will need to check, but i think my motorway lowering activates at around 65mph. |
The later facelifted FF drop at 100mph which is next to useless, oh and the rear wiper stays on if activated instead of delayed sweep. |
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
The 2006+ don't lower. It's a lie. Get on an autobahn and switch to the 4x4 mode, it will *not* indicate a lower height even after 30 mins at 140mph! Land Rover Addict
I dont follow 'Switch to 4x4 mode'? |
