Home > Technical (L322) > Curious Temp Gauge readings....
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi All,
2003 4.4 Vogue LPG.....
Noticed this morning after about 19-20 miles the Temp gauge starting creeping up from the usual 12o'clock position to the 3/4 mark - then about 3 seconds later went back down to usual...!!
On the way home this evening, same thing happened about 3-4 times - after 3-5 seconds back down to normal again....
No rhyme nor reason - doesn't happen at any specific time, up hills fine, down hills, fine, waiting at lights fine, fast driving fine, slow crawling fine....then all of sudden at no specfic time it creeps up then down again a few seconds later!!
There is a whiff of coolant in the air when you open the bonnet, but no wet marks.
Did notice a tiny damp patch under the front valance (if facing the car on the left hand side - just under the front spoiler) the other morning but nothing since.
Any clues??
Many thanks.
Post #133614 30th Jul 2012 4:59pm
Possible water pump or thermostat fault
Post #133625 30th Jul 2012 6:08pm
Saint.v8
Thanks for the reply...
My suspicion is with the Thermostat.....am I right in saying it is an electronic stat??
Post #133628 30th Jul 2012 6:15pm
Doubt the stat would cause a leak unless someone has tampered with it before. Don't know if it is electronic, they are not on most vehicles although it will have wires going to/from the temp sensor to gauge
Post #133635 30th Jul 2012 7:28pm
fisha
Loose earth connection or sensor connection can cause the gauges to flutter quickly. V8 or else ...
Post #133642 30th Jul 2012 8:13pm
Saint.v8
Thanks for the reply, it doesn't flutter - just creeps up stays for 3-4 seconds then slowly drops back again....
I am considering the Electronically Heated Thermostat is at fault....would anyone concur?
Post #133647 30th Jul 2012 8:47pm
I would say thermostat. It is an easy swap on petrol engines. See RSWsolutions who made a video of this. .
Post #133748 31st Jul 2012 1:31pm
Sounds like a sticking/dodgy stat to me. Try the hidden menus for actuall readings. Not sure if the stat uses the same input as the gauge. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #133761 31st Jul 2012 3:11pm
Saint.v8
I have today picked up a replacement Behr Stat and Housing - got to wait for the thing to cool down before fitment (obviously)
I have watched the Legend that is Storey Wilson's video a few times and looking at it, I don't think it is necessary to remove the fan - I will report back on that one!!
I will have to look into the Hiden Menu thing....is this in the wiki pages?? if not where can it be found?
EDIT: Found it...!!
Post #133791 31st Jul 2012 6:06pm
I would have thought doing this without taking the fan off will be a massive pain! As a word of caution do you have the correct fan tool? If not be careful. I used the belt tension to undo mine and Censored the water pump seals. It's possible they were on there way out and the extra force killed them. If I was to do it again without the correct tool I would sacrifice the belt and get one of these http://i01.i.aliimg.com/photo/v1/395407661...ch_Set.jpg would save the pump but also a good excuse to change the belt and at £10 better than being stuck at the side of the road. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #133797 31st Jul 2012 7:48pm
fisha
I think you could do it without the fan coming off. If you removed the air inlet pipe running from the filter to the manifold, you'd have more space. V8 or else ...
Post #133801 31st Jul 2012 8:16pm
Saint.v8
One out and one in....
No need to remove the fan, although I can assume the access would be easier with it removed, although it is manageable if you are tall enough to lean over and get your hand on the lowest bolt closest to the block...a little paitience was needed with that one!!
I did notice a chaffed wire leading to the heated thermostat element (pic attached)
which could have been the culprit.
Filled up with 4 litres of 50/50 coolant mix and ran up to temp and she sat at 12 o'clock for 15-20 minutes quite happily - the drive to work in the morning will be the tester.
Fingers crossed all's well!!
Post #133844 31st Jul 2012 10:45pm
Saint.v8
Well the drive this morning (20 miles) was faultless....
Used the 'Hidden Menu' to display the Temp on the message display for the journey, it rose to 106degC then fluctuated between 106 and 108 all the way with the needle at the 12 o'clock position the whole time....
Fingers crossed, this has been resolved, just gotta wait for the next mission!
Cheers for your input chaps and chapettes!!
Post #133866 1st Aug 2012 8:24am
Glad it was a quick and easy fix! How much was your stat? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #134012 1st Aug 2012 10:01pm
Saint.v8
I got it from GSF Car Parts as there is a stockist just up from work....
Listed at £52.50+VAT - £63.00 - The chap was kind and as I work at the airport and was wearing my Airport ID, he gave me a discount and I got it for a hair over £56
Island 4x4 list it a £46 odd +VAT so that would be in the region of £54 but I would have to pay the post on that one to so would have been closer to the £60-£63 mark in anycase....
The unit is an OEM Behr unit too.....
I am glad it was quick and simple too...hope the next is also!!
Post #134027 1st Aug 2012 11:46pm
