Home > For Sale & Wanted > Rear Light Guard Fitting Kit
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
Does anyone have any of the brackets lying around? Specifically the 4 smaller ones that can be seen in the undernoted picture...
I seem to have lost mine... Sad
 l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #133520 30th Jul 2012 10:50am
T111RDY
....or has anyone got any lying about loose that they could measure up to create a template for me?!?
Cheers,
David l:OolΞΞΞΞΞΞloO:l
Post #133554 30th Jul 2012 1:26pm
T111RDY
As an update, I contacted Bearmach, who are supposedly OE suppliers - but they are unable to provide the fitting kit seperately.... Sad
I think the best bet at the moment would be to have my local metal shop make up some copies for me - so if anyone does have any lying about that they could trace and/or measure for me, that would be most helpful!
Cheers,
Post #133751 31st Jul 2012 1:40pm
Ill have a look, took mine off a while ago but the beackets may be around somewhere. Bear with me...... There is nothing that can't be fixed with a hammer😜😜
Post #133838 31st Jul 2012 10:00pm
They are still attached to the guards. and pretty seized on. Will try and get them off. I have one loose one in any case if i cant remove them you could pattern off, they are handed though.
cant get them off manually totally seized. will try and grind the heads off the screws tomorrow. There is nothing that can't be fixed with a hammer😜😜
Post #133840 31st Jul 2012 10:11pm
T111RDY
Thanks very much! l:OolΞΞΞΞΞΞloO:l
Post #133872 1st Aug 2012 9:15am
Have got the brackets off, if you pm me your address ill pop them in the post. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #133989 1st Aug 2012 8:24pm
T111RDY
PM sent!
Mr. Green l:OolΞΞΞΞΞΞloO:l
Post #134052 2nd Aug 2012 9:16am
