Home > In Car Electronics (L322) > partial freezing/no sound on touchscreen
K9TEO
Anyone had any problems with the audio going off at random times? It's happen 4 or 5 times during a journey. Audio working fine then audio disappeared, orange light on left power switch flashing, touch screen selections for RSE and TV/DVD blanked off, others available but won't select. Could still navigate through sat nav screen. On turning off the engine, the screen stayed on where it was and not the land rover home screen. Seem to reset itself on turning the ignition on some time later, one time though stayed on the LR home screen, then suddenly after a few minutes driving everything came back on. Thanks.
05 vogue supercharged.
Post #134126 2nd Aug 2012 10:18pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
That's a very early SC Smile (surely it's a Vogue SE badged as a 'supercharged'?)
It happens, best bet is to check for water ingress where the amps are, then remove and check each connector and clean up if needed. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #134127 2nd Aug 2012 10:30pm
K9TEO
Definitely 4.2 supercharged, on 55 reg, 12mpg! Will have a look, cheers.
Post #134130 2nd Aug 2012 10:39pm
DMRR
Heh I didn't mean it wasn't an SC Smile SC's were traditionally all Vogue SE's though..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #134152 3rd Aug 2012 9:19am
Battery disconnect, leave a min or two then re-connect can sometimes clear up random issues like that.
I had one where mine re-booted every few minutes which thae above cured.
Certainly worth a try.
Post #134341 4th Aug 2012 4:13pm
K9TEO
Tried both suggestions, but no luck. Now then problem has manifested, and the screen won't even turn on, just flashing orange light.
Anymore ideas?
Post #134574 6th Aug 2012 8:54am
K9TEO
Solution now found, there was a fibre optic error when hooked up to computer. They searched and found several cables had come loose, all back on again.
Post #137748 25th Aug 2012 11:01am
