![]() | Home > Technical (L322) > Dipped head light flickers |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Mine does exactly the same from time to time, drivers side too. 2006 Mercedes CLS
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
Welcome. I had the same thing on another car. New xenon unfortunatley.
Something to do with the coupling I think?
RREIRE Member Since: 22 Jan 2010 Location: Cork Posts: 83 ![]() ![]() ![]() |
I gave my local dealer a call. I gave him my chassis number. He told me it had not been done. |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
Probably the ballast if the bulb is still working. If you change the bulbs, you might want to change them both as Xenon lights change colour temperature with age (they become more blue). The newer bulb will look much whiter by comparison.
Thanks Jayzee I will try that first. I will let you know if it works. |
Good luck, hope it is something simple, but please take care with the voltage. |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
hi I had this on my 05 so i swapped the bulb from passenger to driver side and found my bulb was breaking down so replaced both bulbs and now perfect rgds simon |
Thanks for that. Can I fit bigger voltage bulbs? 4300 is standard. I was looking at 6000watts I think it is watts or volts? Do I have to disconnect the battery first? Or just make sure the light switch is OFF. |
It's kelvins you mean, it's basically the colour temperature. 4300k is usually OE spec, I have 6000k in my Vivaro work van, they're alright but I prefer 4300k As far as I know, they are DS2 HID bulbs, so any aftermarket ones should work and will probably be cheaper than dealer prices.
No offense meant here, but if you are asking these questions, I would suggest you take the car to a garage, or get a mobile vehicle electrician to sort it for you. If you poke around there with the battery connected, the voltage could kill you from the ballasts. |
Hi again i have looked into getting brighter bulbs and found that the dif between 4300k and even 8000k is the colour and not how bright they make the road seem i was advised 4300k are the brightest bulbs |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
Hey guys,
Das Doc Member Since: 24 Feb 2010 Location: Transeuropean Posts: 9 ![]() ![]() |
And what a nice 2p it is!
