Home > Technical (L322) > Air Susp. Inactive?
misteralz
Scotland 2003 Range Rover Vogue Td6 Buckingham Blue
Air Susp. Inactive?
Pinged up earlier after I'd been chucking it about a bit between Braemar and Glenshee... manual says give it 25 minutes for the compressor to cool down. A few hours and 200-odd miles later it's still inoperative. So, what's the damage? Sad 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #134543 5th Aug 2012 9:47pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Is it still at the correct height?
I've had this for the last ~15 months, The error will not clear by it's self. I clear the error with All Comms and it comes back usually within 2 weeks, sometimes just a few hours! Goes up and down fine after the error is cleared.
All Comms says it's "reservoir pressure static" .. My guess is a sticky valve somewhere.
Let me know how you get on, if you take it to a garage. Thumbs Up
Post #134561 5th Aug 2012 11:06pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Hallo, first change the sensor in the reservoir, but I believe that the pressure power of your compressor is not strong enough for the 13,7 bar that are needed for the correct teamplay of ECU, sensor and compressor..., you have the choice of a new one or a repairing...
Many regards, Meerbusch L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #134571 6th Aug 2012 8:08am
misteralz
Think it's sat at access height now. Feels a lot firmer, that's for sure. Was hoping I could disconnect the battery for a bit and that would clear it. Guess not...
Meerbusch, what makes you think it's the compressor? And where would I find the reservoir to change the sensor? I'm guessing it's a pressure sensor you're meaning? 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #134578 6th Aug 2012 9:01am
Meerbusch
Hallo misteralz, the reservoir is under the back door on your driver-site (RHD?), you can see the little pressure-sensor with a lamp, you must dismount a plasticbody under the right side ot the car, but be carefull by let out the air, therefore you must open a ventil in the front at the connector. The compressor is at the most 2002-2005 lazy, I had the same problems two years ago, and noone could help me, every week to the dealer for clearing faults, than I bought a used RSW All comms and could find the mistakes step by step. today even the dealers ask me....
Regards, Meerbusch L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #134600 6th Aug 2012 12:14pm
misteralz
Cool, thanks for that. Not keen on dumping all the air out of it if the compressor is shagged afterall...
Read that the air suspension relies on the brakes for info as well - had the 'check brake pads' message up for a week or so as well. The front inners are nearing the end of their life and I've new ones in stock and was going to replace them tonight. Could this be connected as well or is this just blind hope? 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #134619 6th Aug 2012 1:34pm
Meerbusch
Blinde hope... Wink L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #134627 6th Aug 2012 2:08pm
misteralz
Okay. Is there a way of replacing that sensor without dumping all the air in case it is the compressor that's shagged? 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #134630 6th Aug 2012 2:59pm
Nope .
Post #134631 6th Aug 2012 3:05pm
misteralz
Censored . Next question - is there any way of testing the compressor? Don't want to dump all the air and have an undriveable car given it's the only one we have that can cope with all the family duties. 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #134632 6th Aug 2012 3:12pm
Meerbusch
YES, you must disconnect your battery, than disconnect your compressor electric cable under your fifth wheel, and give 12V + and - to red and brown, you will hear him running, than connect your compressorcable, and than your battery again (because, after fitting is no sign in your display: Airsuspens.inactiv)
seen your thread about gearbox-oil: have bought today some filters and 60 liter DexronIII here in Düsseldorf, payed alltogether for flushing three 5L40E gearboxes 420 Euros : 3 = 140 Euros pro car, = 115 GBP...
Regards from germany
Style your style with style = RangeRover L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #134681 6th Aug 2012 8:52pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
I changed my pressure sensor last winter, when removed it doesn’t drop the air out of the bags in each corner only out of the reservoir due to the non return valve in the valve block front and rear, not sure this helps to test the compressor though
Post #134683 6th Aug 2012 9:03pm
misteralz
Helpful posts both, thank you. Meerbusch, are you saying that disconnecting the battery and reconnecting it will clear the fault in the dash display? Because I think I've found the problem - one of the little plastic arms on the height sensor connected to the driver's side front wishbone had snapped. I'll cable tie it back together for now... Laughing 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #134696 6th Aug 2012 9:55pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Snapped sensor arm on mine to.Got one from Dan and fitted this weekend - but message still on the dash Sad
Post #134712 6th Aug 2012 11:56pm
Meerbusch
You can only clear the faults with GAP, RSW allComms or at the BMW or Landrover Dealer. The disconnecting of the battery is only BEFORE working at the suspension, because after disconnecting electric-parts with cables, you have the problem of the messages, with disconnected battery the system don´t notice any repairs or changes. (Oh my english...)
regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #134717 7th Aug 2012 7:57am
