![]() | Home > Maintenance & Mods (L322) > led halo's |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
| T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936
A quality result |
| Turbo Tony Member Since: 06 Apr 2010 Location: London Posts: 243
Beautiful. Good job Dave. A definite thumbs up from me. Researching my first Range Rover purchase |
| trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 141
Just to clarify re the regs if anyone was still unsure.
had my mot done today, sailed through but more to the point no probs with the led halos or my tri-xenons |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
Just to clarify, just because something is retro-fitted to a car eg additional lights etc does not mean it automatically becomes a testable item under the mot regulations. The lights that are testable under the mot are listed in Schedule 1 of the MOT Inspection Manual. The classic one is front fog lights, although fitted they are not listed in Schedule 1 and therefore are not a testable items. Just remember, If its not in the manual, it's not testable and therefore can't be failed. |
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
Daveo
2 x 126mm SMD LED rings WHITE
Is harness needed if just connecting to side lights directly. I think side lights are black red wires from reading? cheers. Present :2008 TDV8 HSE
you can connect to the side lights direct no probs, the harness gives you 2 switch lines one from 12v ignition live and the other one can be connected to you courtesy light so when you unlock/lock the car they comeand dim out. never used it my self ut thats what it does. V8 facelift Range Rover Autobiography 22" wheels.
Looking at some halos on eBay do you know if rrs lights are same size as ffrr internally?
| BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429
Have you set up a business in Glasgow …
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837
£480?????? I rather think not! Got - 2017 SDV8 Autobiography in Loire Blue
