Home > Off Topic > confessions time? - who has got any 4x4 stuck
Page 3 of 3 <123
Budgie
On the peat moor above Helensburgh with my old Rangie.
It looked OK but I found grassed-over drain. Rolling Eyes
This one wasn't me, I saw it by the main road on the way into Stornoway when they were digging foundations for a house.
Post #135452 10th Aug 2012 11:19pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
A couple of good posts about the dangers of winches here. I am a trained fires service winch instructor and I am scared silly when I see some cars fitted with winches knowing that the owners are probably not trained.
If used correctly no winch rope/cable should never snap. Every winch should have a maximum torque and if the cable is rated over that pull it should never break. Failure is usually when the anchor point is not up to scratch or when the cabe is not maintained correctly. Any shackles used should be rated over the maximum torque/pull of the winch too.
Basic safety training should be essential before anyone can use a wich, although that will never happen sadly. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #135460 11th Aug 2012 12:03am
My FF is fecking useless on wet grass! Embarrassed itself many times... OK its on 22"s and road tyres but still!
Funny thing though, put it on snow and its ace! Work that out Shocked
Craig Embarassed
Post #135482 11th Aug 2012 11:23am
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Craig it must just come down to the RIGHT kind of snow Laughing
Post #135499 11th Aug 2012 2:29pm
I definately agree that if you've never got stuck, then you aren't trying hard enough Thumbs Up
No piccies of my best stuck moments, but does a failed hill climb count ?
A real lesson for me that locked diffs can sometimes get you into more trouble than not having them. I was lucky, but the guy who went after me & decided that it just needed a bit more speed Twisted Evil ......
Needless to say, I went to play on a different part of the site after that
Post #135594 12th Aug 2012 12:41pm
Deasy
Without sounding condicending, do you know how to react properly to failed hill climbs??
Locked diffs won't make a difference if you do, they will help Very Happy
Post #135597 12th Aug 2012 12:54pm
What I do is engage reverse & roll back down - feet off everything - is that what you were asking ?
What I meant was that without locked diffs, I wouldn't have got as far up the hill and therefore not into trouble in the first place.......
Post #135603 12th Aug 2012 2:18pm
Deasy
Yep thats the one. Just many people don't realise engine braking works in reverse aswell as in 1st low
Also on newer models hill decent also works in reverse
Post #135616 12th Aug 2012 4:26pm
As above, low range, hdc, reverse or 1st depending on which wnnof the vehicle is facing downhill Smile
Hdc speed also change between low and high range too, I guess so as obtuse engine braking. This is irrespective of being in a gear or neutral FYI Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #135617 12th Aug 2012 4:32pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Alistair are those pics at Tixover? 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #135655 12th Aug 2012 9:48pm
Deasy
Also I think its on the my05 onwards, mabee later not sure, but you can adjust the hdc speed using the cruise control up/down function
Post #135668 12th Aug 2012 10:41pm
Tried on mine but to No effect ;( maybe on the TR system vehicles that works as work on the d4's I had Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #135675 12th Aug 2012 11:41pm
The one and only time I've ever been 'stuck' is on a greenlaning trip in my 110 five years ago.
Just exited a wet, steep grassy field after a slippery climb and nonchantly drove into a 'puddle', which turned out to be a bit deeper than first thought. A Series 3 109 had just walked it, so I figured I'd be fine...
Wrong line and down one front wheel went, leaving the diagonally opposite rear waggling in the air.
As help was arriving, I then realised I'd not selected diff-lock, so tried that and out I trundled.
Either through some kind of driver skill (me?!) and / or decent tyres, I've never been stuck since. Si. <This is my name.
Post #135685 13th Aug 2012 8:21am
I didn't get stuck myself but this is what happened to my Discovery shortly after I sold it to a local yoof. Rolling Eyes
It was immaculate when he got it. Big Cry
Post #135687 13th Aug 2012 8:58am
Yep Thumbs Up
Post #135781 13th Aug 2012 9:16pm
Page 3 of 3 <123
