Home > In Car Electronics (L322) > Intermittent crackling through sound system
Over the last few days this problem has resurfaced , when switching the ignition on and the audio kicks in there is a intermittent crackling sound that's goes through the full speakers something like a constant click clicking sound ....
Typical the last time it happened the car went into the stealers but as per usual no fault at the time was found , granted to get rid of the crackling I have to maybe turn the car off 2 or 4 times doing lock to lock ...
Mostly just a PITA at times Rolling Eyes
Post #135492 11th Aug 2012 12:51pm
Googsy
loose decal ? Rolling with laughter Sorry Mick couldnt resist! sounds like a loose wire somwhere have you checked the AMP in the rear and connections ? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #135493 11th Aug 2012 12:56pm
can be very annoying mick Sad
is it the same problem you had in february? http://www.fullfatrr.com/forum/topic9967.html?highlight=crackling
...can you toggle between each set of speakers to maybe isolate the noise or is it on all of them.. ... - .- -.
Post #135494 11th Aug 2012 1:26pm
Yeah same fault stan , the sound goes through all the speakers regardless off toggling Thumbs Up
Post #135495 11th Aug 2012 1:31pm
you've probably checked all the connections and rear screens [if you got them]
i suggest recording it on your phone then show it to the service manger... ... - .- -.
Post #135496 11th Aug 2012 1:42pm
Post #135498 11th Aug 2012 2:22pm
BrianC
I had this problem and it was a faulty Bluetooth module
It would crackle and then cut out the whole audio system
Post #135527 11th Aug 2012 8:02pm
