Home > Technical (L322) > Vehicle raising slowly message
winslo
2005 Range Rover Vogue Td6 Adriatic Blue
I viewed a range rover last night with a view to buying it.
When was driving I stopped, dropped the suspension and then drove away to make sure the vehicle would raise, it came on with the message "vehicle rasing slowly" and the light on the middle setting was flashing for ages, they guy said it was normal! However after owning several range rovers I know it's not, I've never seen that warning before!
So my next question is.....has anyone else had it? Could it be a leaking airbag taking a while to fill or the compressor on its way out.
Thanks
Richard
Post #135559 12th Aug 2012 9:14am
Could be many things, but my bet would be a weak/worn compressor
Post #135562 12th Aug 2012 9:24am
T24RES
i've had that once or twice. I would suspect it is not normal and something is worn (compressor). Factor in some discount if the rest of the car is worth a punt.
Post #135563 12th Aug 2012 9:26am
My first guess would be the compressor is on it's way out , I suppose it would depend on how old the car was they don't last that long it seems . 2008 MY Supercharged
Post #135564 12th Aug 2012 9:27am
Sad Me too, but only occasionally.... Got me thinking.. Using some tools, electrical tape and black magic, would it be possible to use a small high pressure tyre pump (halfords fag lighter job) as a replacement? Thoughts please.. Previously..
Post #135569 12th Aug 2012 9:32am
winslo
It is a 55 plate td6, up on the miles too at 137k
My thought was compressor too
Will call the guy today see if we can work out a deal
Thanks all
Post #135572 12th Aug 2012 9:36am
mpirie
I've seen the "vehicle raising slowly" message before after checking (or "playing" according to my wife) with the ability to raise or lower the car.
If the compressor is getting hot, then it can cause that message. Of course, if the reservoir is empty and a request to raise comes in, then not only will the compressor be raising the car "slowly" but will also be trying to fill the reservoir?
I'd give the car a good run then see if the message reappears?
Mike
Post #135573 12th Aug 2012 9:38am
winslo
Just thinking to myself....the guy said he had put a new battery on recently
Do you not need to turn the wheel side to side a few times or if you dont it can mess up the suspension?
Just a thought?
Post #135575 12th Aug 2012 9:40am
mpirie
Yes, if he hasn't reset the suspension after a battery change, it can cause many different errors.
Simple enough to check, but also remains a useful bargaining tool Wink
Mike
Post #135576 12th Aug 2012 9:42am
