![]() | Home > Technical (L322) > Transf failsafe mode |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432 ![]() ![]() |
Can you complete your car profile please (makes it easier for the right people with similar cars to comment) .
Rockportpurple Member Since: 04 May 2012 Location: Scarborough Posts: 38 ![]() ![]() |
Sorry i forgot to add its an 02 plate 4.4v8 vogue
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1038 ![]() ![]() |
Does the TRANS FAILSAFE PROG message appear before you've even selected Drive?
Hi yes it does actually now i come to think of it
Most likely either a low battery voltage issue or possibly a faulty transfer box shift motor potentiometer.
Thanks guys i appreciate the replies is there a test i can do on the potetiomiter?
Brian GOG Member Since: 08 Dec 2011 Location: leeds Posts: 57 ![]() ![]() ![]() |
Start by testing the battery condition and do an amp drain test. The vehicle so go to sleep after 16 minutes or so. In sleep mode you should have a reading of 0.01A to 0.02A anymore than this will discharge the battery quicker. Earlier models had more issues with battery drains as they have several operating systems trying to work together. If you need any help on doing the test I'm sure they will be a thread on here or you can just give me a ring. ( My number is 01132539000 )
Might be worth getting a solar top up charger if you are leaving it 4/5 days. Plug into the accessory socket in boot area. Remember to unplug before starting car!
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
My TD6 does this occasionally when I muff up a start. Dash goes ding and Trans safe mode pops up. Reset start car and all fine.
Hi guys thankyou for the replies
