Home > Technical (L322) > BATTERY DRAIN
Page 2 of 3 <123>
Brian GOG
United Kingdom 2002 Range Rover HSE Td6 Epsom Green
Hi Steve
First off get the vehicle in a state where you can work on it without disturbing 'sleep' mode. So bonnet, doors, tailgates and cubby box all open but latched to fool vehicle. I would then do 2 tests one lock the car with the remote and check drain after 16 - 20 mins and then do same again but just lock it with the key in the door. The difference should only be the volumemetrics. You are going to have to have this switched off to do your testing or you could cover them up - up to you. I prefer to do it the way I was shown! You may want someone to check to readings for you whilst you've got your head buried behind the glovebox or in the boot. I would remove each fuse in order and refit it and then note down which make a difference. Again this is how I was shown I find it easier to check each fuse in order then going back and forth etc. Let me know how you get on.
Best of luck,
Brian
Post #135664 12th Aug 2012 10:17pm
STEVE57
England 2007 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Hi brian
Thanks dor all your help , im unsure how to leave doors tailgate latched,and fool the car to go into sleep mode ,how do i fool it? i know i can tape down the bonnet and cubby hole pin switches, also the second test with the key to lock the door will that not set the volumetric alarm,
Thanks
Steve
_________________
2004 range rover vogue 4.4,Lpg, java black 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #135667 12th Aug 2012 10:40pm
Brian GOG
I just a slim screwdriver in the latches to put them in the latched position. Then you can just pulled the screwdriver back out to unlatch them just open the handle - sometimes you may have to apply abit of pressure on the claw mechanism if it's abit stiff. In theory locking the vehicle with the key disables the volumetrics eg: leaving the dog in the car. By doing both locking tests it allows you to elimate ( or identify )the volumetrics quickly.
Post #135670 12th Aug 2012 10:47pm
STEVE57
Brian
I will let you know what i find
Thanks
Steve 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #135672 12th Aug 2012 10:56pm
STEVE57
more info
started to pull fuses found when fuse 52- 25amp fuse is removed the amperage draw goes down from 150ma to 50ma, the fuse controls the front heated seats, but when fuse removed it stops the heated seat controls and the climate controls fan controls fan speed switches etc
anyone have any ideas?
thanks
steve 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #135754 13th Aug 2012 6:34pm
could be the fsr [final stage resister]
http://www.rswsolutions.com/index.php?opti...;Itemid=78 ... - .- -.
Post #135758 13th Aug 2012 7:25pm
STEVE57
the fsr has been changed 5 days ago new genuine land rover part 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #135763 13th Aug 2012 7:49pm
Fuse 52 serves the HEVAC ecu which also controls the heated seats.
If you pull out fuse 12 as well as fuse 52 it will isolate the heated seats and leave only the ac / heating controls.
This should indicate where the current leak is ie seats or ac controls.
It's possible the new FSR is leaking current, I don't think they are particularly well made from new hence all the problems.
Post #135775 13th Aug 2012 8:52pm
STEVE57
[mod edit-no need to use the quote when replying ]
so could the new fsr be faulty? 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #135780 13th Aug 2012 9:16pm
It is possible
Post #135782 13th Aug 2012 9:21pm
Not so much faulty but I don't think the manufacturing quality is particularly high.
I have a suspicion that if you checked a batch of new FSR's a good proportion would leak current to some degree. Some would be better than others.
I know when I changed mine due to current leakage the new unit still leaked current albeit to a far lesser degree than the unit it replaced which I accepted as being "good enough".
I still think they are a unit that could be significantly improved at manufacture.
Hence them routinely failing after a few years even though the design has been changed at least once.
They get very hot in use particularly in hot weather which I assume adds to the failure problem.
I would still carry out the Fuse 12 check to clarify things.
Post #135784 13th Aug 2012 9:31pm
STEVE57
ok, thanks will check fuse 12 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #135785 13th Aug 2012 9:41pm
STEVE57
Hi
Did amp draw again draw was 150 ma removed fuse 12 no difference, removed fuse 50 draw went down to 50ma so its somthing on fuse 52 taking out fuse 12 makes no difference, 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #135852 14th Aug 2012 4:01pm
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
hi guys
I’ve had a battery drain for months every 2 days battery is flat Censored Censored Censored
so I check yesterday and when the car went to sleep it was drawing 0.586 amps Big Cry
so I started pulling fuse after fuse to i pulled the stereo fuse.
straight away it dropped to 0.060 i carried on pulling all the fuses but it never went any lower then that
it was the satnav unit not turning off so I’ve left that out now as its Censored anyway
is 0.060 amps good enough or does it need to be lower
I’ve got the big 110amp bosh battery
Post #135855 14th Aug 2012 4:10pm
hevac control module on fuse 52 and 34..have you pulled fuse 34 to see if it makes any difference.. ... - .- -.
Post #135856 14th Aug 2012 4:12pm
Page 2 of 3 <123>
