Home > Technical (L322) > Air Suspension inactive ......
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Suddenly getting this error (recorded from EAS activate device) - battery fine and appears to clear itself after a while but has happened each day this week when I start the car.
1.--Current Faults---->
Articulation Validity Fault
Faults Cleared
<-END Faults
0000011-20-17-16-00-37-02-30-01
Can anyone decode the error and point me int eh right direction of what is seemingly failing? "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #135879 14th Aug 2012 7:00pm
search "air suspension inactive" [with quotes] ...there's loads re this... ... - .- -.
Post #135883 14th Aug 2012 7:12pm
Brian GOG
United Kingdom 2002 Range Rover HSE Td6 Epsom Green
Hi Mr P
Not sure on the error code as it's different system to the Autologic we have. The fault relates to the readings from the height sensors that don't tally with each other. Can you check the readings of the individual heights sensors against each other in real time data with your equipment? If one is different when compared against the others thats where you should start. Also check the front air springs to see if they are ok and not leaking. If may need to jack the wheels up to allow the shocker to reach it's full travel. Dirt gets inbetween the spring and seat and rubs a small hole over time. If the car has gone over a bump and the hole has leaked some air the ECU will command a refill of the strut but log the fault that the corner momentary was low. If it sees that enough times it will bring the message up on the dash.
Hope this helps.
Brian
Green Oval Garage
Post #135930 15th Aug 2012 12:07am
MrP
Thanks GOG! - thats what I was looking for - had a thought it maybe a sensor rather than the normal EAS stuff. I will check them this weekend. "On first name terms with my local Dealer......now."
Post #135972 15th Aug 2012 9:57am
MrP
Had a search but can anyone tell me if it is possible to test the height sensors on the l322? It would seem that it is a sensor issue as the eas inactive goes away when you get to motorway speed and the car correctly drops to the right setting, when you slow up it gets confused and the error appears. I don't have any of the flash diag tools. I do have access to the SE to view the ODBII data if that would show it. "On first name terms with my local Dealer......now."
Post #136952 21st Aug 2012 9:36am
Had this fault when I had hole in airbag.
Go to off road mode and have a good listen all round for hissing air. Try lifting by each wheel arch. Leave in off road mode over night see if you have a saggy corner (whole front or rear may drop). .
Post #136961 21st Aug 2012 10:12am
MrP
Had one of those before so did check to see if that was the case again but doesn't appear to be. Is there anyway to get a decode of the error I posted or is it generic and what I have from the eas activate tool is all I can get? "On first name terms with my local Dealer......now."
Post #136963 21st Aug 2012 10:27am
This post more or less covers it: Either airbag or faulty sensor. If you don't think it is airbag, try changing the sensor first (much cheaper!!)
http://www.fullfatrr.com/forum/post19308.html
It may also be that the sensor arm has swung round by 180 degrees? Have you had the front end apart for anything? Or the sensor linkages might be broken/loose etc. .
Post #136975 21st Aug 2012 11:37am
MrP
Thanks Joe90 - the fault is the same so looks like a height sensor. If dan is reading this can he tell me how much they are? "On first name terms with my local Dealer......now."
Post #136987 21st Aug 2012 12:28pm
Sensors are around £25 per corner
Post #136994 21st Aug 2012 1:16pm
MrP
Has anyone done a photo gallery of how to get at them / check them before I start trying to find my copy of Rave? Sure its a sensor now as at one point today it thought it was in off road mode on the warnings but the lights said normal then it changed back. "On first name terms with my local Dealer......now."
Post #137050 21st Aug 2012 6:41pm
No photographs but more or less self explanatory when you see them
A couple of small Torx bolts (I think they are Torx) hold the sensor onto the body and a 10mm nut and bolt onto the suspension. Take care removing the electrical plug as you can easily damage it if forced
Post #137075 21st Aug 2012 8:03pm
MrP
Many thanks all, last question - how can I test the sensors as I don't know which one is faulty? Short of it being obviously broken(snapped) is there a test I can do? Are they resistance based or digital signal to the bus? "On first name terms with my local Dealer......now."
Post #137081 21st Aug 2012 8:39pm
If your vehicle has the original sensors they will most likely all be on the way out. The connector where it bolts onto the suspension corrodes and the rubber splits.
Post #137106 21st Aug 2012 10:48pm
MrP
I would expect they are original - thanks for the info, will order replacements. "On first name terms with my local Dealer......now."
Post #137107 21st Aug 2012 11:03pm
