![]() | Home > Technical (L322) > HELP URGENT |
HDC = Hill Descent Control |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Have you tried wiggling the gear stuck to ensure its in park! One of Gaz's fav things to try. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
STEVE57 Member Since: 27 Apr 2012 Location: solihull Posts: 103 ![]() ![]() ![]() |
low voltage.low battery??????? 2007 supercharged ,Cairns Blue with Navy & Parchment Interior |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 ![]() ![]() ![]() |
when i went out to her this morning notised the brake lights were lit she started fine about eleven oclock, had to do a ten mile run so when i got back started to have a look ,thats when i tried the other key nothing but my concern is the brake lights being on whith no key in and it being locke up been in touch with land ranger sevices in stockport he say bat and poss key lost its memory to car. any more advice more than welcome have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
right guys update: striped down consol and tried the key ,with a wiggle and jigal the key turned stearing colom moved and she started, shut her down tried again and the same thing wont turn so have discounted key lost memory, and bat volts, looks like ignition switch/barrel problem.
Crumbs muck etc gets into the ignition barrel, you could try blowing it out with an airline |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35703 ![]() ![]() |
i thought you had done that already |
autobiorob Member Since: 18 Nov 2011 Location: Peterborough Posts: 33 ![]() ![]() ![]() |
I had this problem with the key and a few places couldn't solve it. Believe it or not the previous owner had spilt coke over the console and barrel etc. and it had never been thoroughly cleaned up causing a sticky film over connections. I had took it to places and they put all the machines on to tell the problems but there isn't a traceability setting for spilt coke so sometimes its not the obvious. Cost me hundreds to not solve it but only £50 charged to clean it up properly. No problem since........fingers crossed! Once a Blue, Always a Blue |
update 2, ignition swich/barrel taken off car switch cleand but barrel kaput so think have solved that problem ,
Update 3 ignition barrel and swich all re stripped and cleaned and put back together seems to work now but not tried on car as too dark now |
Pete
Can anyone confirm that when a brake switch is disconnected as to whether the brake lights should be on or off? |
