Home > Technical (L322) > front suspension higher than rears
been messing with my suspension settings today and noticed that the front was 10mm higher than the back..anyone have ideas why this is ? ... - .- -.
Post #136546 17th Aug 2012 5:05pm
Coz you been messing with the settings...Doh Shocked
Post #136548 17th Aug 2012 5:26pm
original settings john..... ... - .- -.
Post #136549 17th Aug 2012 5:27pm
Have you tried disconnecting the battery for 20 minutes Whistle
Also try THIS Laughing Laughing
Post #136551 17th Aug 2012 5:37pm
Whistle ... - .- -.
Post #136560 17th Aug 2012 6:31pm
Laughing Laughing
Post #136565 17th Aug 2012 6:37pm
i found this contributed by joe90 and it shows a difference of 10mm , but why?
Post #136566 17th Aug 2012 6:41pm
Sounds to me like it's throwing a hissy-fit because you're thinking of selling it Rolling Eyes
Post #136569 17th Aug 2012 7:00pm
I guess because you may need more height/ground clearance at the front as you are more likely to approach obstacles going forwards? .
Post #136597 17th Aug 2012 10:00pm
makes sense tim, also what about when you brake the front goes down and the extra 10mm accounts for this maybe.. ... - .- -.
Post #136600 17th Aug 2012 10:05pm
Stan, put yours flat then get someone to drive it past you... They dont look right if not up slightly higher on the front! Rolling Eyes
Craig Thumbs Up
Post #136617 18th Aug 2012 12:51am
ahebron
New Zealand
Maybe its so they emulate the squat that early 2 door Classics used to get under acceleration. Wink
Adrian VW Amarok 2014 Highline auto
Post #136623 18th Aug 2012 6:56am
Andy
Mine rears up like Bigfoot when pulling away. I swear it could climb over small hatchbacks in much the same way! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #136897 20th Aug 2012 5:01pm
fisha
I love seeing RR's boot it off the line and the rear end sit down ... gives it a look that no other 4x4 has.
I always assumed the fronts had a bigger gap cause the fronts needed more space for the wheel which turns as well as going up and down. V8 or else ...
Post #136914 20th Aug 2012 8:59pm
seems normal then, thanks all.. Thumbs Up ... - .- -.
Post #136947 21st Aug 2012 9:16am
