Home > Technical (L322) > Instrument Cluster failure
Have you checked the pad sensors just to be sure? One front and rear. There only about £6 might be worth changing them first just to eliminate a dodgy sensor. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #136667 18th Aug 2012 2:42pm
ramclaren
United Kingdom 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
So, went all the way to Southampton today with my new (used) instrument cluster to get the specialist to either fix mine or replace it with the new one. The "check brake pads" message came up on both clusters so the fault is definately not with the cluster. I'm going to have to go back to LLR Land Rover (who fitted the brake pads and told me the fault was with the cluster) and get them to check the sensors again. Lucky I didn't go with thier advice and fit a new one at £650!!!
The specialist told me that it could be the ecu in front of the battery, but not sure.
Nightmare!!!!!
Post #136803 19th Aug 2012 8:17pm
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
Sorry to hear that Rich. l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #136850 20th Aug 2012 9:48am
