Home > In Car Electronics (L322) > Electric steering not working.
henry nelson
England 2003 Range Rover HSE Td6 Adriatic Blue
Hi every one, since disconecting the battery for something else the steering electrics have not worked, nor has the memrey button on the drivers seat. any one any ideas?
Cheers Henry.
Post #136629 18th Aug 2012 9:08am
daveym
United Arab Emirates
Has it gone into 'Transport Mode'? Are the footwell lights coming on?
Post #136686 18th Aug 2012 5:06pm
henry nelson
yes foot well lights are working, dont know about the transport mode.not a sat nav car and it does not have its own stereo in, ( information button stopped working) put my own stereo in. Do i need to get it put on a computer to check transport mode?.
Post #136723 19th Aug 2012 6:32am
Disconnect the battery again... Temperamental Censored these RR's
Craig Thumbs Up
Post #136731 19th Aug 2012 8:06am
henry nelson
Is there a particular way to do the battery.
Post #136734 19th Aug 2012 8:23am
Make sure when you re-connect it you dont dab the battery terminal on and off several times... Try and re-connect in one movement...
Craig Thumbs Up
Post #136736 19th Aug 2012 8:44am
henry nelson
How long should i leave it disconected ?
Post #136769 19th Aug 2012 2:33pm
Half an hour should do you. On reconnection start the car and turn steering wheel lock to lock to clear all dash faults (may need a little drive about too) .
Post #136773 19th Aug 2012 3:11pm
henry nelson
Cheers Joe will try that on Tuesday, working nights this week.
Post #136776 19th Aug 2012 3:32pm
henry nelson
Ok have disconected the battery for 30 mins but the electric steering still wont wont work/or seat memory. Do i need to have it put on a laptop to check for a fault ect.
Post #136980 21st Aug 2012 12:10pm
Um, fuses ?
From handbook:
Fuse 20 covers both Drivers seat and Steering column,
Fuse 23 Steering Column,
Fuse 29 Heated Steering Wheel,
Fuse 21 Passenger Seat,
Fuse 52 heated seats front .
Post #137003 21st Aug 2012 2:02pm
henry nelson
The seat electrics still work apart from memory. Fuse 20 ok. Fuse 23 ok.
Post #137010 21st Aug 2012 2:56pm
Stumped ?
What did you do when you disconnected the battery in the first place? Retrace steps, undo what you did, see if that fixes it.
Otherwise it is diagnostics time: RAC AllComms or IIDtool or whatever...... .
Post #137018 21st Aug 2012 4:19pm
henry nelson
thanks Joe 90 i think it is diagnostics time. Cant think of anything i did differant the first time. Cheers HENRY.
Post #137032 21st Aug 2012 5:08pm
Whistle .
Post #137041 21st Aug 2012 5:58pm
