Home > Technical (L322) > Door Card
markdotreed
Door Card
I've read just about every thread on door locks not working. My passenger door will not unlock with either the key or the internal button so I thought I'd have a go at lubricating it myself.
On about the 100th time of trying the door unlocked so I took advantage of this opportunity.
Watched the Video on MeTube on how to remove the door card (Very usefull) but when I tried to remove the wiring everything came off easy enough except the large plug that connects the electric window button to the door. The two small ones have those slide clips but for the life of me I can't work out how to remove the middle one.
Any ideas? or is it designed not to be removed??
(had someone hold the card while I sprayed everything and it made no difference by the way but have decided to have another go before I bite the bullet and send it in to be repaired.
Next trick I read somewhere is to push down on the button before trying to unlock... Regards
Mark
2009 D4; 1993 Classic 3.9 VSE
Post #137126 22nd Aug 2012 9:13am
mjdronfield
Well, not a great lot of use to you, but I replaced the speaker on a mates 4.4 petrol, and he really struggled to get that connector off. Very tight.
RAVE isn't much help, as it says "disconnect 6 multiplugs"..........
Other than fully understanding what you need to do to get the plug off, which I'm sure you've done, I can't think of much.
Is there a connection further down where you can disconnect there instead ? Long shot - can't remember.
Unless someones stuck it on previously......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #137141 22nd Aug 2012 10:04am
markdotreed
Teased it with a small screwdriver for a while and it wasn't going anywhere..... Will take a picture of it later.... Regards
Mark
Post #137147 22nd Aug 2012 10:37am
Do you mean the black square shaped plug in the middle? If so, slide a flat screwdriver in the gap in the end and gently lever it out (works on a similar principle as the two other turn clips in the window panel) but slides out releasing the plug rather than turning through an arc like the other two...
Hope that makes sense pal... Good luck...
Craig Thumbs Up
Post #137310 23rd Aug 2012 1:01am
markdotreed
Had another go at it last night. Worked out the plug (thanks anyway Craig) but after loads of fiddling and half a can of WD40 nothing is any better.
So, am going to have to book it in...... Boo.. Regards
Mark
Post #137320 23rd Aug 2012 7:25am
Why book it in Mark? Your almost at the latch you would need to change! Disconnect your battery, undo the four bolts holding on the door airbag and secure it out of the way (with cable tie or sticky tape) then pull back the black inner cover, remove the 3 or 4 torque screws holding the latch to the door (open the front door, where your childlock would be on the rear door you will see the torques bolts around the latch)
Then simply slide the latch out of the door removing the two cables and an electrical plug...
Craig Thumbs Up
Post #137334 23rd Aug 2012 8:47am
markdotreed
OK.... I had the airbag off and I had the inner off....
Is it the whole lock that you replace then and are they off the shelf items..... (Waits for Dan to reply)
I don't mind doing it myself if it's as straight forward as you suggest. Regards
Mark
Post #137362 23rd Aug 2012 10:40am
mjdronfield
Is this any use ?
Though you could have it already......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #137366 23rd Aug 2012 11:03am
markdotreed
No, I didn't.... Thanks Regards
Mark
Post #137367 23rd Aug 2012 11:06am
mjdronfield
Its all in RAVE, which you can download from the Wiki..........
http://www.fullfatrr.com/wiki/RAVE_downloads
Well worth it..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #137371 23rd Aug 2012 11:36am
markdotreed
Ok... Old door latch is off, Keith Gott had a new one in stock so I went and got that, little bit of transferring of parts around and about to do the refit. Will put some pictures ip later Regards
Mark
Post #137546 24th Aug 2012 11:34am
markdotreed
And....it's all working again..... Thumbs Up Regards
Mark
Post #137566 24th Aug 2012 12:05pm
down to the pub then... Thumbs Up ... - .- -.
Post #137570 24th Aug 2012 12:11pm
Fell inside the door cavity Shocked
Post #137590 24th Aug 2012 1:47pm
