Home > Maintenance & Mods (L322) > Range rover tow bar
Glm
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Range rover tow bar
Hi all ,help req my range rover 07 has 2 brackets fitted to the rear underneath with westfalia on them as I can fit a bar to carry a tow bar ? Will I need a full kit or is this apart of the kit ? Any help appreciated Current tdv8 range vogue 07
Post #137261 22nd Aug 2012 8:06pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
You'll find help if you use an appropriate thread name Thumbs Up
Post #137291 22nd Aug 2012 10:37pm
Glm
Modifications I think might be the right thread !!! Current tdv8 range vogue 07
Post #137498 24th Aug 2012 12:02am
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Those brackets are not required if using an OEM armature.
But if you get the older armature you will need to grind off and use the 2 right angled exhaust mounting brackets.
Post #137503 24th Aug 2012 7:25am
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
looked into modifying a bracket a couple of years ago..
it was highlighted to me that if anything unfortunate happened that insurence will not cover it.
i now stick with CE marked items...
Post #137563 24th Aug 2012 11:59am
