![]() | Home > Technical (L322) > Air con not blowing ice cold |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I think I need a re-gas but not 100% sure. Basically, when the air con is running, it's not ice cold air that's coming out like it used to a few months ago.
Are they right about the compressor not engaging if there is no gas in the system? I can sort of see the logic in that, as it probably acts as a lube and if there isn't anything in the lines, the compressor would burn out? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Yes, the compressor won't engage if there is no gas. As Flashman it is most likely the condenser in front of the radiator that is leaking |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
I use a system called "EZ Chill" that's available from Halfords to check and top up my aircon.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
As your car is 10 years old the chances are the refrigerant has slowly leaked away over the years thro the seals. It's likely a regass would solve the problem for you.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35808 ![]() ![]() |
my condenser went that way noddy, replaced it and re-gassed and all is well..thread here somewhere on it.. ... - .- -.
I like the sound of that EZ Chill. Might try it.
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
I had the same problem last summer on my Td6 - lack of use over the winter. A simple re - gas sorted it. It looks like fifty quid is the going rate ?
Had mine re-gassed in March for free |
Go on.... 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Pay for two get the third one free |
specialist garages are your best bet, they test with ultra violet lights to find the leak ... ... - .- -.
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
I had a similar issue witht he A/C not blowing cold (absolute disaster for last weekend's heat wave). I took it to the local guys who put it onto their machine for a regas and said exactly what they told you Noddy ... An hour later (and depsite the machine having gone through the leak test prcedure) we noticed that it had stopped regassing - they said the machine would have detected that the pressure wasn't being maintained on regassing (although we could hear the compressor going on a test) and therefore stopped. No money taken as it didn't feel
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
Thought mine wasnt working right, then notices that the vent temp control (not the climate knob) was set to warm, set to cold and was all good. |
