![]() | Home > Technical (L322) > Help needed - Electrical problem ? TDV8 |
Bantam Member Since: 20 Feb 2012 Location: Cheshire Posts: 27 ![]() ![]() |
Hello - any ideas / suggestions welcome on this one.....
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35806 ![]() ![]() |
sounds like it has affected some electrical component....you should use the 'bomb' aerosol type which does a better job getting rid of the bacteria.. ... - .- -.
Update: battery charged, car started and ran well with no probelms or faults.
Needs a multimeter to see what the alternator's doing. Engine running the battery should be at 14-15 volts. Anything less and your alternator's up the swannie. |
Hi Guys - Thanks for replies, turns out it was the Alternator - Air conditioning foam was a red herring.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
You can always check the alternator charging level by going into the screen hack 753 mode and looking at vehicle signals.
