Home > Technical (L322) > Front Suspension Depressurising
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Before I get on to my question a BIG THANKS to Joe90 Bow down for the how to on changing the front air springs Thumbs Up
I have just changed the OS front air spring as this one had a hole in it.
Now Im wanting to change the NS front air spring but have a problem depressurising it as I have NO block where there should be one Shocked
Anyone else came across this?
There are 3 holes where the block should bolt to......just no block Big Cry
Post #137600 24th Aug 2012 2:38pm
I thought there was only one block and both sides connected into it
Post #137611 24th Aug 2012 3:38pm
Bob the B
Thats what I thought but I dont have the block.
Checked other side and no sign of it there either!
When you look at the pic you can see the 3 holes for bolting the block to and also the electric clip/connection is cable tied to the yellow pipe.
Post #137614 24th Aug 2012 3:48pm
WTF ! Shocked
For the uninitiated, this is what should be there:
You may need to check back through the history on the car find out what has been done to it....it must be on the car somewhere otherwise the Air Susp wouldn't work properly? Surely not on the other side as even LHD cars have the valve block in this position.
Also maybe worth asking Duckworths Dan to ask a "tech" if they have ever come across this before. Your yellow pipe does look "new", mine was quite faded. I wonder if in a previous fix it was moved inside the car for some strange reason?
What a PITA Confused .
Post #137615 24th Aug 2012 3:49pm
Thumbs Up [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #137628 24th Aug 2012 4:30pm
Bob the B
But the question is can I still deflate the air spring without it and WITHOUT stabbing it with a knife?
Post #137637 24th Aug 2012 5:09pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
You can depressure direct at the struts, softly open, when the air begins to flood out, stop the open procedere with the 12-key, and wait some minutes, until the strut is empty.
Regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #137638 24th Aug 2012 5:17pm
Yes, as Meerbusch says, if you can get a 12mm spanner on the nut at the top of the airspring and turn it enough to allow a trickle of air out, then wait a good while for all air to leave the spring. Battery disconnected (best) or minimum air compressor fuse removed, of course!
You need arms like snakes, fingers like a monkey and with eyes in the end, and a special shape-changing spanner to achieve this Smile .
Post #137643 24th Aug 2012 6:00pm
Bob the B
Post #137644 24th Aug 2012 6:02pm
Looks like your car has been...Tangoed Whistle
Post #137645 24th Aug 2012 6:07pm
What's a t-w-a-t-o? .
Post #137654 24th Aug 2012 6:54pm
Joe90 wrote:
What's a t-w-a-t-o?
The car has been Tangoed and is Censored 'd Whistle
Post #137684 24th Aug 2012 11:54pm
Bob the B
Cheers for all the replies Thumbs Up
Post #137697 25th Aug 2012 6:19am
Bob the B
Post #137698 25th Aug 2012 6:19am
Bob, can you not trace the pipes and see if the valve block has been relocated (which I doubt).
Makes me wonder if the valve block is really required.
Before the airbag problem was the suspension working perfectly?
Post #137703 25th Aug 2012 8:04am
