![]() | Home > Technical (L322) > Installing the Audio Connectivity Module LR004806 |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
found this tom, dont know if its the same,
| Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608
I got one installed in my 05 range rover 06my. It is suitable for pre 2007 touchscreens it's just a bit of an ordeal to install. Once you have removed the dash and get to the back of the sat nav it should be plug and play. Correct me if I'm wrong peoples.. |
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244
Thanks for the confirmation, so it looks like on the earlier models the electronics box is mounted in a more inconvenient position under the centre of the dash.
| speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727
Top of the dash off and passenger glovebox assy out and youll be good to go plug and play you just have to be creative in mounting the silver controll box as you dont get a lot of slack on the fiber optic cable thats in your conectivity box of goodies as it connects into the cd multi changer also i would allow a weekend of fiddling if you have never stripped the dash down onto no6 Range Rover
Nice one, thanks all! Tom
| All times are GMT |
