![]() | Home > Technical (L322) > Battery or alternator problems? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
If you suspect you have battery or alternator problems This is an inexpensive but useful voltmeter to allow you to simply check where the problem might lie.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
Also, if you suspect that your battery or alternator is not working correctly you can use the in car diagnostics to see what the voltage is and how its charging.
Does that apply to all vehicle years? |
And also http://www.fullfatrr.com/wiki/Secret_Codes
Thanks for that. |
