Home > Maintenance & Mods (L322) > coolant leak
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
coolant leak
hello
has any one had this prolem
my 2002 4.4 v8 uses a lot of coolant without any visable sign of leaking
hawever when the expansion tank is full and i have been queing steam comes out of the bonnet it is localised to the left hand side
it wont do it when the coolant has dropped in the expansion tank to just above minimum
i cannot see any damage to the expansion tank (have not removed yet)
im thinking one of three failings
1, the cap (is this Possible) Very Happy
2, the tank Smile
3, the radiator (doubtfull given the steam) Crying or Very sad
thanks to all Thumbs Up 02 Range Rover HSE Zambezie silver 4.4
Post #12653 7th Feb 2010 10:16pm
Seen this on RR.net .......
Coolant Level Warning
Apparent coolant leaks (early models through 2006) may be due to a faulty coolant level float absorbing coolant and sinking. ====================================
Post #12656 7th Feb 2010 10:20pm
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
How many km on the clock?
How much coolant ? XJC, RRV8, Series1 86 and 107% of real pleasure
Post #13000 11th Feb 2010 5:09pm
daveo
hi mate had this last month....for sure its the header tank they are prone to pin holes and under normal use you wont even notice, but in traffic it will get nice and hot and then sprays out, my one was so fine it looked likr 2 hairs and only after putting my hand there discovered it, i changed my one as i didnt want it to get worse or pop
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #13003 11th Feb 2010 5:29pm
RRAUS
Australia 2003 Range Rover HSE 4.4 V8 Tonga Green
Andy, I just went through the same thing from what I detect. Coolant level warning came on and then, thinking I would be okay for a day or two Mad , kept driving. Then all of a sudden, heard a gurgling sound so pulled over straight away. Turns out my thermostat was blocked which resulted in the pressure building up and cracking the reservoir. The local mechanic expalined that after 7 years of hard plastic cooling/heating/cooling this will happen. $500 later a new themrostat and reservoir. Now: 2003 Epsom Green HSE
Gone: BMW 530i Hi-Tec M Sport (Titan Silver)
Gone: BMW 328i Convertible (Orient Blue)
Gone: BMW 525i (Diamond Schwartz)
Gone: Audi A4 2.8 V6 Quattro (Ming Blue)
Post #13053 12th Feb 2010 10:47am
andyw
just a quick update all
changed the expansion tank cap (12 quid) topped up and went to find traffic
the result wich i could not get it to do the steam thing as mentioned before, Smile
got back thinking all was well and parked up at work, came to the end of the day and a small (fist size) patch of coolant front centre Big Cry extended the EAS and crawled under for look and you may have got it by now but the radiator looks like it has sprung a leak and drips coolant so its off for a new radiator Big Cry it should be covered by the warrenty Confused
will let you know as it happens 02 Range Rover HSE Zambezie silver 4.4
Post #13056 12th Feb 2010 11:41am
andyw
Hi all thought i would up date you all, my indie confirmed that the radiator was mullered and would need replacing. i rang the warrenty company and tey confirmed the radiator was covered Very Happy so booked car in and got the indie to do the work (today its in) just got a phone call
1 the warrenty company will only pay for a non OEM radiator (i get the difference Big Cry )
2 they will only pay for the fitting time of the radiator ( i get the difference)
3. and finaly unbeliveable as it is because the coolant has nothing wrong with it they wont pay for that even tho the removal of the radiator will spill most of it into a bucket Big Cry
the good news is that they are paying the majority of the bill and i will be getting a chunk,
i did half expect this and as with any warrenty company they will always try and go the cheapest (get out of paying route) Censored
in my case the car came with the years warrenty and it cost me nothing i have a thousand pounds to spend and i will be making sure i get every last penny out of them
if i can (bring it On)
i must admit though they do make sence as the coolant was not broken it had just formed an escape commitee.
hopefully pick her up tonight with a gleaming new radiator
problem soughted
regards
andy 02 Range Rover HSE Zambezie silver 4.4
Post #13773 24th Feb 2010 11:07am
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Who is the warranty company out of interest? 15MY SDV8 Vogue SE
Post #13777 24th Feb 2010 12:07pm
thanks for keeping us updated on the problem and solution Thumbs Up Discovery 4 HSE
1993 90 Tdi
Post #13780 24th Feb 2010 12:36pm
SteveMFr
Site Sponsor
Unless this is spelled out in their terms of agreement, the non oem rad is BS. Find a solicitor. I've seen oils, coolant, etc excluded before, though I think warranty co's are not doing themselves a favor with terms such as these: I can't imagine that, after having to drop several hundred on a radiator, 1000+ on a steering rack, or several thousand on a transmission, their balance is going to look much better due to saving a couple of quid on fluids. And their reputations will have suffered quite a bit - they need to put that on the books as well.
I realize that it is prob too late, but in this case you would have probably been ok with the aftermarket radiator. All aftermarket radiators I've seen or heard about, come from the aftermarket sales branch of Behr - who is also the oem supplier to LR (ask me how I know). As such, the aftermarket rads are identical to the oem's minus the LR part#. Rolling Eyes
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #13784 24th Feb 2010 1:21pm
andyw
hello all got her back and had a good old chat with the indie mech
it was £45 pound more for an oem and a years warrenty on it so i went for that option so it was not that bad and 15 quid for the OEM coolant
steve thanks for the advice and i will look at the policy and see were i go from there
the company by the way is VGS (i have never heard of them ethier) but was free and does pay in the most part despite my shouting
if however i had paid for it i would not be happy at the moment it well and truely softens any bill needed to be paid
as close to something for nothing as you can get me thinks Thumbs Up
as matter of interest the radiator was kept and it was absolutly warn out
the steam trail out around the header tank was i small hole on that side tat acted like a kettle
cheers all for the support
Post #13805 24th Feb 2010 7:24pm
