Home > Technical (L322) > What is the box located in the Passenger footwell?
GTJones
Wales 2002 Range Rover Vogue Td6 Epsom Green
Hi Guys
Another question from a novice? running some wires down the front passenger footwell and found a white box fitted behind the trim panel with a large multi pin loom (Purple Top) that was not connected?, box was there and loom but as i say not connected?
Don't want to connect just in case but not sure what it is for, any help appreciated.
Gary
Post #137807 25th Aug 2012 11:09pm
Not sure what you have found, but you can bet your last dollar it's fubarred
Post #137809 25th Aug 2012 11:25pm
GTJones
My car is a 2002 L322 Vogue, so not sure if it is the pre-wiring for a phone? although there is no phone fitted, the part looks OE.
Will connect it up and see what goes bang Smile
Gary
Post #137811 25th Aug 2012 11:37pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Put a picture up if u get a chance.. Thumbs Up
Post #137814 26th Aug 2012 12:53am
Have a close look at it and see if it says headlight levelling ECU written on it somewhere... (one of the only ECU's in a FF that tells you what it is!)
A white box, not quite as big as a fag packet but slightly thicker?
Craig Rolling Eyes
Post #137830 26th Aug 2012 11:09am
GTJones
Hi Craig
That sounds like the one i mean, i presume it should be plugged in ?
found the section in the workshop manual (Picture below No12)
says it is the Automatic headlamp levelling ECU (bi-xenon headlamps only)
next is do i have Xenon? how would i tell?
Thanks for all you help guys.
Post #137859 26th Aug 2012 8:04pm
2002 TD6 most likely not
Post #137863 26th Aug 2012 8:30pm
Do you have a halogen bulb or an eliptical headlight? (ie does your headlamp have a visible bulb in a chrome holder like a normal car or a shark eye type?)
The eliptical type means its bi-xenon... Thumbs Up
Craig Wink
Post #137875 26th Aug 2012 9:29pm
mjdronfield
HSE and Vogues have Xenons standard......
SE's do not.......
Least thats what the brochuire says....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #137963 27th Aug 2012 2:33pm
GTJones
Had a look and they seem to be Xenon so will plug it in, can't imagine why it was unplugged though?
Post #138015 27th Aug 2012 6:22pm
