Home > Technical (L322) > Too much oil in TDV8
Benfelrr
United Kingdom 2007 Range Rover Vogue TDV8 Tonga Green
Hi, just wondering if anyone with technical knowledge of the TDV8 might be able to advise me on the following. I have the 3.6 TDV8 and it was recently serviced by my local Land Rover dealer , who are pretty excellent to be honest. Anyway, I noticed that the oil is to the top of the red plasitc on the dipstick so a mm or two above full. they advised this was fine, but would appreciate anyones thoughts here. Is that OK or is it cast in stone that the max level is the max level and must not be exceeded?
Thanks. ! Ben.
Post #138066 27th Aug 2012 9:04pm
Get it taken out ASAP, overfilling is as bad as under filling. Can put pressure on oil seals which will start leaking and also foul up the catalytic converter
Post #138069 27th Aug 2012 9:07pm
does sound like its been overfilled..I'd do what John has suggested. ... - .- -.
Post #138070 27th Aug 2012 9:09pm
Happened to me with a Porsche. The dealer collected the car from my work and gave it a full service, about 2 weeks later I notices a few drops of oil on my garage floor, so checked the level on the dipstick. It was over ¾" above the full level. I called the dealer and said I had a leak which I suspected was the crankshaft rear oil seal, I asked if overfilling would have caused this and was told that it most certainly would as it puts extra pressure on the seal, he then went on to tell me that it was a gearbox out job and it would cost over £300. I would have loved to have seen his face when I told him the oil level was ¾" over the mark on the dipstick and was serviced by them two weeks earlier.
Give them their due they did replace the seal and supplied me with a nice 911 whilst doing so Thumbs Up
Post #138071 27th Aug 2012 9:26pm
Benfelrr
cheers guys, the garage said they would happily drop some oil out. I should stress it is only a mil or so above the dot.
Post #138082 27th Aug 2012 10:30pm
