Home > In Car Electronics (L322) > Venture cam
onyx
England 2005 Range Rover Vogue Td6 Java Black
Venture cam
Hi,just purchased a used venture cam off fleabay and it's seems the battery is shot ?.when you press the button nothing happens and the oval doesn't light up.tried to charge it but when docked nothing again ?,I have put a test bulb across the 2prongs and when you switch ignition on it lights up so I take it powers there.Camera doesn't light up when docked or register on touchscreen.
Anything else I can try or is it a return job.
Many thanks
Post #136894 20th Aug 2012 4:36pm
CBH25
Australia 2003 Range Rover Vogue 4.4 V8 Santorini Black
there are lots of posts about this if you search.
the rechargeable batteries in venturecam only last so long.
Many of us have cracked it open and replaced the AAA batteries without any problems.
you just need tagged batteries and soldering skills. L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
L322 4.4 Vogue MY05 - Sold to my brother
P38 4.6 HSE MY97 - Regretfully sold
Post #137889 27th Aug 2012 1:32am
stu
Hi, yes I have replaced batteries in a cam, bit of a fiddle but easy enough. You know that if the battery is totally flat it will take some time to charge it enough to register cam on screen!
I would suggest deleting any other cams already paired on screen, plug your one in and go for a drive. If it is going to work it will need 5-10 mins to sort itself out. You will see the messages on the screen if it is going to work.
Good luck. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #138097 28th Aug 2012 7:31am
Charmer
Could anyone please tell me where the suction mount is normally stored?
I have Venture Cam but cannot for the life of me find the suction mount! Sad
Cheers
Post #138897 1st Sep 2012 12:34pm
normally in a pouch stored any where really.. ... - .- -.
Post #138899 1st Sep 2012 1:06pm
In the boot sometimes under the spare wheel failing that cubby hole in the boot right hand side Thumbs Up
Post #138903 1st Sep 2012 1:37pm
Charmer
Thanks for letting me know.
I have looked everywhere and it looks like mine has gone AWOL.
Post #138980 1st Sep 2012 9:46pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Think there are also a few versions of Venturecam, so you may also have to get the correct frequency aswell. Also on a thread on this forum somewhere Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #139718 5th Sep 2012 10:25pm
stu
i didn't realise that there were different frequencies for venture cam!! this may explain why i have cams that power up, register on the screen but don't produce a picture.
is there any way of finding out what frequency works in what cars? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #140195 8th Sep 2012 6:52pm
RRVSE
Hi Stu, this was the topic I was thinking about...
http://www.fullfatrr.com/forum/topic2781.h...+frequency
2 frequencies, 434Mhz and 2400Mhz (2.4Ghz).
Checked mine (2006 VSE but 2007 model year) and camera has 0682 on back with what looks like a number 1 in a circle after it. Checked on-board diagnostics and doesn't specify the frequency in the vehicle specification / software displays so not sure how you know which version you have, unless one version superceeded the other, in which case someone on this forum ( like Daveo ) may know when the cameras moved to say 2.4Ghz and so may then be able to establish which version you need. Steve
Post #140669 11th Sep 2012 10:25pm
the 433 MHz frequency is for activation and the 2.4ghz is tha transmission frequency..(I think) ... - .- -.
Post #140679 11th Sep 2012 11:16pm
Gaylexx
2007 Range Rover Vogue SE TDV8 Zermatt Silver
Hi
The green oval flashes then stays lit on mine for a few seconds but then 'dies' is that cos the battery is shot? Screen says it is charging but happens every time I switch venture cam on?
Post #141028 14th Sep 2012 1:43am
possibly the battery, you have a 5 year old range with a 5 year old cam battery... i would think the battery has deteriorated buy now.. ... - .- -.
Post #141043 14th Sep 2012 8:46am
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Gaylexx wrote:
Hi
Mine did exactly this and was battery, I'm working on a post with photos, on how I repaired mine. All the info is thanks to other members on this forum, but I couldn't find many pics and pics help me!
Very Happy
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #141175 14th Sep 2012 9:38pm
Brewster
England 2006 Range Rover Vogue SE TDV8 Buckingham Blue
Venture Cam
yeah another one here with a green and black paper weight in the glove box!
I was going to ask the question of how to split the unit to get at the batteries without damaging it, do you think you will be putting that into the how to guide or could you just quickly tell us here /...also a link for your source for the batteries maybe?
cheers
B ...Always time for a brew !!
2006 TDV8 Vogue SE
Post #142342 21st Sep 2012 1:11pm
