Home > Maintenance & Mods (L322) > Trans cooling |
Buy an oil cooler with inline stat set at say 85'c as i know they exist and just use that. better than worrying about more water circuits and electrics FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
28th Aug 2012 12:09pm |
jay-p Member Since: 26 Aug 2012 Location: SELSTON / NOTTINGHAMSHIRE Posts: 46 |
You mean instead of the water cooler? This is another option but it then goes back to no cooling at standstill, but then again every other auto I have had has coped fine with a standard air cooler, even my r34 skyline running 400bhp |
28th Aug 2012 12:29pm |
Just sit it infront or behind the current oil cooler so it gets good airflow on the move. and if you really want airflow maybe break into the electric fan circuit and use something like a small 12cm PC case fan to pass air over it enough at standstill?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
28th Aug 2012 12:38pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1254 |
A read of the web suggests that an optimal temp for transmission oil interns of preserving the fluid is in the 80 to 90 deg area.
29th Aug 2012 10:49pm |
Very good point mate, still cant make my mind up what route to go |
30th Aug 2012 8:29am |
Wanna hear something scary ?
30th Aug 2012 7:01pm |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
Fisha:
30th Aug 2012 8:58pm |
Bloody hell that's hot I think the best way is to remove the cooler and replace with a conventional cooler, that way there's less heat going into the coolant and the trans stays at a more moderate temperature, as long as its big enough I can't see it being such an issue at standstill, not quite sure what the most efficient location would be though? |
30th Aug 2012 9:19pm |
I found out the hard way today which is the return I thought I read somewhere and also assumed it would be the pipe that's attached just above the pan on the passenger side of the engine, this resulted in about 5L of fluid being pumped all over the place It's actually on the selector side |
30th Aug 2012 9:24pm |
