Home > Maintenance & Mods (L322) > Hissing sound from rear (drivers side) wheel
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Heard yesterday morning but appears to be intermittent and no change in suspension height after a long motorway journey (and no warning messages) - is this a "wheel off and spray the air suspension with soapy water test" ?
Post #138308 29th Aug 2012 11:25am
Is it a click then a hiss ? If so could just be the car levelling itself out . 2008 MY Supercharged
Post #138323 29th Aug 2012 12:22pm
VaguelyVogue
Sadly just a hiss - it seems to self level quite happily without any clicks or hissing.
Post #138336 29th Aug 2012 1:34pm
Budgie
Are you sure it's not just the rear suspension dropping to access height?
Mine drops a wee bit on the rear when I turn it off to allow access to the boot.
Post #138338 29th Aug 2012 1:49pm
Could be the pressure relief valve at the compressor dumping excess air as the car comes to a halt.
Post #138340 29th Aug 2012 2:07pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Try putting it in off road hight and leave over night. If its down at one corner I would say you have a leak Crying or Very sad
Post #138369 29th Aug 2012 4:51pm
You are catching on Bob Wink .
Post #138386 29th Aug 2012 6:44pm
Bob the B
Joe Ive only had experiance with the front and what to keep it that way Whistle
Post #138410 29th Aug 2012 9:17pm
VaguelyVogue
Left in off road height overnight and it was the same height at each corner in the morning - so maybe it was a pressure relief valve at the compressor dumping excess air (I first noticed this on a warm day).
Post #139004 2nd Sep 2012 9:20am
Bob the B
Fingers crossed your right Thumbs Up
Post #139137 3rd Sep 2012 8:30am
Most FF's wont achieve full height with an air leak... Most leaks are masked somewhat by the construction of the bags and as they extend the leak gets bigger, hence most not achieving full off road height...
Craig Thumbs Up
Post #139141 3rd Sep 2012 8:50am
VaguelyVogue
Hmmm - I didn't of course measure the actual height reached Craig, just that the car moved up !
However, whilst on a couple of 250 mile drives this weekend there was a dashboard warning message along the lines of "suspension height adjustment off, normal height only" and the lights went off on the height control display.
When driving back in cooler weather last night, the lights were all on again and no messages - so I'm starting to think that there is a leak somewhere (matching the intermittent hiss) and the compressor is running too long and possibly overheating.
Sounds like my local garage will be getting a visit - I couldn't find a leak with the rear wheels off on Sunday morning, but it doesn't hiss all the time.
Post #139149 3rd Sep 2012 9:34am
Bob the B
Have you tried taking your spare wheel out and checking if the leak is from the compressor, or is the hiss definatly ouside the car?
Post #139303 3rd Sep 2012 11:15pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
If the leak is other than in an air spring, I agree.
My experience is that most air spring leaks occur where the bag "rolls over", as this is the highest-stress area on the rubber. Excluding failed seals at the ends, of course, which aren't all that common.
If the bag has developed a leak at the roll-over in standard height, the leak could be sealed when you're at motorway height or off-road height.
Checking for an air spring leak would require setting at EACH height & measuring, then leaving it overnight with the system disabled (leave a door open on the P38, pretty sure that does it on the FFRR as well) and measuring in the morning.
If you don't do that at every height, you might miss a leak.
In fact, just putting it at offroad height almost guarantees the fish-mouth crack in the air spring will be sealed if the leak is at the roll-over at standard height.
If it drops from offroad height overnight, you could have valveblock leaks, airline leaks, etc, etc.
Get all up in there with the soapy water, checking at ALL heights. Jim
2000 NAS HSE
2005 NAS HSE
Post #139306 3rd Sep 2012 11:38pm
VaguelyVogue
Ok - more weekend testing is obviously needed - thanks for the hints on finding the potential leak!
As an aside, when I was jacking up the car to remove the wheels are the weekend, the only way that I could stop the suspension adjusting itself was to lock the suspension in access mode (I tried drivers door left open, boot lids left open and passenger door left open - but each time I raised the car it adjusted the suspension).
Post #139323 4th Sep 2012 9:09am
