Home > Maintenance & Mods (L322) > LED rear lights.
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
LED rear lights.
Hi guys,
I have just fitted a set of rear lights off of a 2010+ model to my 06.
The fog light is permenantly on (half brightness).
What's the solution for this?
Thanks in advance.
Post #138384 29th Aug 2012 6:20pm
daveo
there are a number of ways to sort out all the probs with the lights, depends on how confident you are with a bit of wiring and the use of some components, or there is a man who makes a purpose built ready to fit unit,just slightley larger then a ciggy packet and made nice and tidy in a alloy box to disperse the heat, this will stop the fog light issue and the flickering as well as the indicarors V8 facelift Range Rover Autobiography 22" wheels.
Post #138390 29th Aug 2012 7:20pm
Stryke
Hi Daveo,
I'm good to wire up some components.
What do I require?
I get flickering on startup and the fog.
Indicators operate fine.
Will this work?
http://www.powerfuluk.com/products/range-r...rs%29.html
Thanks.
Post #138392 29th Aug 2012 7:44pm
daveo
that unit will fix the blinking fogs but you will still get flashing on the othe lights as the LCM will send a pulse to the lights ans thats what makes the flash it will do this all the time you have the car running, you need to use some resisters to full the LCM in to thinking it has the standard bulbs,how do you indicators/hazards work.
http://www.powerfuluk.com/products/range-r...5-ohm.html V8 facelift Range Rover Autobiography 22" wheels.
Post #138397 29th Aug 2012 8:20pm
this is from our wiki, hope it helps..
http://www.fullfatrr.com/forum/topic9647.html ... - .- -.
Post #138400 29th Aug 2012 8:41pm
Stryke
Thanks, had a look at that and used it as a guide for installing.
However doesn't mention where he got the box of tricks from?
Post #138423 29th Aug 2012 10:18pm
as dave mentions, powerfuluk sell them and they are available on ebay as well... ... - .- -.
Post #138460 30th Aug 2012 9:30am
Stryke
Well, according to Powerfuluk, the kits for the 05-09 dont work so they stopped selling them.
Can't find anything on ebay...
Post #138479 30th Aug 2012 11:17am
Yes, they work on the early models but not on the late ones... I think they are working on a new system for the 05> but have no idea how long it might take...
Craig Thumbs Up
Post #138484 30th Aug 2012 12:11pm
Stryke
Hi Craig,
How did you get yours working?
Thanks.
Post #138506 30th Aug 2012 2:10pm
daveo
stryke, you can get a pair of units that will do the lot.plug and play. around £100 for the pair, let me know if your intrested and i will dig his number out.. V8 facelift Range Rover Autobiography 22" wheels.
Post #138549 30th Aug 2012 5:53pm
Stryke
Hi Dave,
I've sent you a PM regarding something else, please have a look.
Will speak over pm.
Post #138554 30th Aug 2012 6:13pm
