Home > Technical (L322) > Air con not blowing ice cold
2 years ago, no cool air, so went to Kwik Fit for a regass. They said everything OK, but never really worked well, I got clouds of "something" coming out the vents. A quick "screwdriver to the nipple test" (choose which nipple wisely!!) showed no pressure in system.
Specialist identified a leaking condenser (air con rad) replaced this, regassed and been good to go since.
Find a specialist. There should be a mobile one who could come to you with all the right kit, or ask your indie or local garage who they use. .
Post #137585 24th Aug 2012 1:15pm
STEVE57
England 2007 Range Rover Supercharged 4.2 SC V8 Cairns Blue
air con re gas
hi
had mine regassed last week by mobile air con service, i see you are in birmingham, the guy i use comes to your home or work, he checks out the lines condensor etc vacuumed out system ,put in lubricating oil for seals , leak detect fluid, and new gas air con now works great.i will pm you the air con engineers phone number
steve 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #137607 24th Aug 2012 3:24pm
Andy
Bought the EZ chill from Halfords. Works a treat! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #138565 30th Aug 2012 6:46pm
Budgie
Give it a week and then check the pressure again (with an old can connected Wink ) to see if it's lost anything.
That way you know if there's a leak somewhere.
Glad it worked OK though, it's a good DIY system isn't it. Very Happy
Post #138590 30th Aug 2012 8:24pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Had a new condenser fitted earlier this month after mine passed a leak check and was re-gassed twice (once at independant, once at dealers)
Both times Air-Con lasted 2-3 days.
Can't give you a cost as it was warranty Razz
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #138616 30th Aug 2012 9:25pm
