Home > Wheels & Tyres > Wheel nuts for different alloys Guide
Page 2 of 4 <1234>
Andy
anyone? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #14015 27th Feb 2010 7:54pm
Andy
itguy wrote:
Right - this should become a sticky as I've seen this asked more than once in a few days!
Here is the pic
I can't see why the taper is present on the chrome one or the purpose of it (unless the 7 spoke alloys are thicker). Doesn't the nut pull tight against the washer? If so, they look like they are both the same depth to the washer. The tapered section effectively passes right through the wheel holes. From the pic, it looks like the chrome one is slightly longer due to the taper, so wouldn't the tapered section come into contact with the hubs first, which would then tighten before the washer has started to seat, making the rim loose? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #14019 27th Feb 2010 8:06pm
StevieH
Its not the length that matters it's the girth...sorry just being smutty. The silver ones are about 3mm wider to fit all post2006 wheels. Expect Ken will be along soon to put you all right but this topic has been covered before.
Stevie
Post #14027 27th Feb 2010 10:08pm
Andy
So, if I want set of locking wheel nuts, I just ask for post 06 ones then? I have the wheel nuts with the 7 spokes, but 2 lockers are missing. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #14167 2nd Mar 2010 9:33am
yes.
I will make this thread a stick and rename it slightly. Discovery 4 HSE
1993 90 Tdi
Post #14169 2nd Mar 2010 10:37am
Andy
Not sure what nuts I have here, but they won't touch my studs. Smaller internal diameter on the chrome ones 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #14422 6th Mar 2010 7:54pm
BrianC
ive just bought a set of supercharged wheels from a 06 plate, the problem ive got is my wheel nuts are the smaller black one's,
i am after a set of the new style anyone got a set lying around for sale ?
also do you think the black one's would be ok ? i dont
Post #60377 14th Apr 2011 6:14pm
no , they wont fit..
you need the ones on the right with a 23mm shank..there are plenty on ebay, remember to get lock nuts as well. ... - .- -.
Post #60379 14th Apr 2011 6:19pm
BrianC
Ok I'll have a look thanks
Post #60383 14th Apr 2011 6:37pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
LR part RRD000011 for up to 2005 wheels
Post #139178 3rd Sep 2012 11:46am
Thumbs Up ... - .- -.
Post #139179 3rd Sep 2012 11:51am
DTaylor
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Chawton White
I have a 2005 l322, going to be putting these wheels on
are these wheel nuts the ones I need?
http://www.ebay.co.uk/itm/20-WHEEL-NUTS-FO...2a087bca8f
Post #189059 17th May 2013 11:10pm
Yes they will fit but so will these. I have them fitted on mine.
http://www.ebay.co.uk/itm/20x-Genuine-Allo...19d23f8266
Post #189082 18th May 2013 8:23am
DTaylor
thanks a lot, got them done today, the old wheels had spacers and allsorts. thanks vmuch
Post #189150 18th May 2013 7:05pm
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Hi, just to doubly double check before spending a lot of money tomorrow.
My 2005 car has the earlier black nuts. Tomorrow I'm buying a set of 06 wheels that need the bigger silver nuts, which I also have yet to buy.
Can someone please confirm that the thread on both types of nut is the same (ie the wheel studs/hubs are a constant thing all the way through RR production) so I dont end up with a set of wheels I cannot fit? NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #328623 19th May 2015 4:01pm
Page 2 of 4 <1234>
