Home > Technical (L322) > Windscreen - top seal coming loose
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Well, had a new noise last night and this morning i noticed that the top windscreen seal had popped out about 6cms. Put it back and drove to work to discover it had popped out again. Same on my return this evening. It appears to be about 5mm to short to fit back under the roofline retainer bit....
Is it ok to silicon it back or is it kaput????
Post #139409 4th Sep 2012 5:13pm
mpirie
If the windscreen's been replaced then it's possible the fitter allowed some of the glass sealant/adhesive to stray out of the correct area.
The top seal has a shaped back to it where it's supposed to hug the edge of the glass.
If any sealant/adhesive has strayed then the seal may not have been replaced properly, allowing it to come away.
I've had this happen to a couple of beemers and my last range rover.
Black setting silicone should be enough to hold it in place.
Mike
Post #139441 4th Sep 2012 7:06pm
DavidP
Mike,
Thank you for the answer, i will silicon it back. It's not had a new windscreen only thing out of the ordinary is that i washed it last week.
Thanks again
David
Post #139495 5th Sep 2012 6:23am
