![]() | Home > Maintenance & Mods (L322) > Knock knock knock from the engine |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Is one of the drive belts de-laminating? Sometimes the outer canvas can come away and flap. |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
And if you increase the revs, the speed of the noise increases as well? Previously..
Zeus Member Since: 18 Dec 2011 Location: Dumfriesshire Posts: 46 ![]() ![]() ![]() |
Thanks Simes, Contraband.
Water pumps tend to start with play in the bearing, which then knocks out the seal. Any play at the edges of the fan? |
Just checked the fan. Yes a bit of play at the fan tips but looks more like from the torquatrol unit rather than the water pump pulley. With the tension on the belt would I be able to feel play in the water pump?
Usually play in the fan in the water pump. They aren't too bad to change - allow an hour or so. Fit all new belts while you are at it - they are easy to get to when it's in bits! |
Check the belt tensioners as the bearings in them do eventually wear |
Thanks Gents.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35748 ![]() ![]() |
...as for the bits you need, ask in duckworths section for a price, dan is always eager to help.. ... - .- -.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
When your changing the water pump be careful when you pull it out. Tere are 2 aluminium pipes running from the pump to the back of the engine. They are only sealed with o rings. You will get new ones with the water pump. To change the ones on the back is a total T.w.a.t so make sure they don't come out! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1504 ![]() ![]() |
And when putting the pump back on, be careful with the new o-rings that they don't get snagged by the pipes. A lube of them with something helps to prevent this. It's a |
Thanks Chaps,
