![]() | Home > Maintenance & Mods (L322) > Air suspension inactive |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Well, just reading between the lines on the code description, sounds like a hole in your rear right airbag. COuld be compressor having to over work to keep it pumped up, or compressor is worn/tired and can't cope with demand. Finally there may be a leak in the pipework somewhere or from the air reservoir.
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Ive had he same fault. But sometimes it would be front axel sometimes rear. Spoke to a few people and they said it was the bags but at £300+ that's a lot for a trial and error. Eventually stripped my compressor and got it working much better and haven't had any fault for 4months plus. So my fault was the compressor over working. Never had it sagging when left for long periods etc. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| max abbi Member Since: 19 Oct 2010 Location: Newtownabbey Posts: 18
Thanks guys for the quick replies. I think as Rob suggests I will try stripping the compressor first. and then work my way towards the airbags. Does anybody know anything about the rebuild kits available on eBay? What alternative compressor would fit? Rob love the avatar! |
Your stuck with the current compressor. The rebuild kits on eBay are from a guy on here (Merch....".. Or something like that. I stripped mine and used some 1200wet and dry to rough up the piston ring and used some high vac grease and works a treat. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Well I've bought a rebuild kit of eBay . The guy assures me that the fault is due to the compressor, so when it arrives and I get it fitted I will keep you posted. Fingers crossed ! |
Ok problem fixed !!!
| Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 327
Dear max abbi, I am happy about your good ending problem |
| All times are GMT |
