Home > Maintenance & Mods (L322) > Locking doors when driving off...
Andy
Is this a programmable option? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #14021 27th Feb 2010 8:18pm
SAppie
Re: Locking doors when driving off...
On my 2007 model it is an option. I had the stealer enable it, but it was at an additional cost. The only thing is, it locks when driving off, which is gr8, but it doesn't auto unlock when you turn the ignition off and remove the keys, which it does on our disco3, so that is a bit annoying, but I guess that that's not an option on my car.... can't have everything... Anyone know if it should do that? or can be setup to do that too?
Post #14025 27th Feb 2010 9:40pm
It can also be done on the RR Sport by the driver via the instrument binnacle. I'm afraid its a dealer issue. Discovery 4 HSE
Post #14033 27th Feb 2010 10:21pm
Kilovolt
United Kingdom 2010 Range Rover Vogue TDV8 Atacama Sand
Out of interest, on an MY10 it is a settable option on the shiny LCD instrument binnacle menu.
Stealer not required to make this change Rolling Eyes
I know................. not much help. Neutral Currently running FFRR MY10 TDV8 3.6L and a Disco 3 XS Commercial (tank like but very effective as a Company van). Plus one mint condition Track Day Car in the form of an E36 M3 3.2L Evolution circa June 1996 with lots of go faster bits and only 52k miles on the clock! Oh, plus a few bits to make it slow down really quickly as well! Luvverly.
Post #14036 27th Feb 2010 11:54pm
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
The dealer should be able to give you a form to fill out all the options you want set, Hunters charged me £60 to have auto lock doors and headllamp delay (you have to pull the flash switch for this though so pretty damned useless). Bit galling to be charged for this after being parted with £40k for the vehicle. 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #14038 28th Feb 2010 12:14am
SAppie
Kilovolt, thats gr8, at last they are allowing the owners do the changes themselves.. Can you tell me whether it also unlocks the doors again if you stop the engine? SO, you drive off and the doors lock, but then when you arrive at your destination, you turn off the enine and the doors unlock again???
Post #14045 28th Feb 2010 9:20am
Whilst on a 2010 you can now select auto-locking on pulling away from the user options to keep up with Land Rovers comedy approach to electronics you still have to hit the button to unlock them when you want to get out or pull the individual handle twice . Banging Head 2008 MY Supercharged
Post #14048 28th Feb 2010 11:14am
Vogue
its meant to be like that. Its to prevent thieving illegals from opening the door and nicking your handbag when you pull up at the lights, junction, Mcdonalds, garage etc etc.
At least if you are in charge of the unlocking, you can check first that its safe to do so...
Post #14064 28th Feb 2010 8:56pm
StevieH
Vogue i feel i must point out that we have some perfectly fine home grown thieving junkie basturds and if it was an Olympic sport i feel we would do well Laughing
Post #14069 28th Feb 2010 11:03pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I set the headlight delay myself via a thread on this forum and works fine. Obviously I have to flash the lights as I get out to trigger the delay, but it's no hardship. Think it was just a case of getting in the car, locking the doors, then holding the LR button on the keyfob whilst holding the headlights on flash until the words 'headlight delay' appeared on my LCD display. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #14117 1st Mar 2010 3:49pm
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
On an 02 this is only programable by using TestBook/RovacomLite or similar, it is not available by using the dash buttons.
Stewart.
Post #14210 2nd Mar 2010 9:43pm
Andy
I have headlight delay on mine and I don't have to flash the headlights. I just switch off the engine while the lights are still on, then turn the switch to off. They stay on for 40 secs 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #14444 7th Mar 2010 10:06am
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
I must make a trip to the dealers as I'd like the "follow me home" lights activated.
I'd also like to see the list of options available too! TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #14491 8th Mar 2010 9:08am
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Do a search on the ''other forum''.
That document is there...
Post #14500 8th Mar 2010 1:09pm
