Home > Technical (L322) > towing
daveo
towing
at some point before i bought my car, my towbar and electrics have been removed from the rear of the car but the electrics have been left fully wired and put in the towbar compartment, just wanted to know if i should get something come up when i plug a trailer board in, as i dont... V8 facelift Range Rover Autobiography 22" wheels.
Post #140328 9th Sep 2012 10:20pm
Don't get anything on mine
Post #140330 9th Sep 2012 10:24pm
daveo
no indicator to say its plugged in or working.. Question V8 facelift Range Rover Autobiography 22" wheels.
Post #140333 9th Sep 2012 10:40pm
No nothing. My Classic displayed a light but nothing on the FFRR
Post #140335 9th Sep 2012 11:43pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
You should get the green trailer light flashing with the indicators (assuming your trailer indicators work).
Post #140336 9th Sep 2012 11:55pm
T24RES
Mine has a green trailer lamp lit permanently after plugging in (08MY)
Post #140338 10th Sep 2012 1:20am
mzplcg
As does my 07MY. I recall that the facelifted ones (with Jag/Ford electrics) do this and the BMW based ones have a light which flashes with the indicators.
Both are only to satisfy the trace light regulations. If the light doesn't flash on the older ones it means indicator failure on the trailer, and on the newer ones the green light stays on all the time but the indicators flash at double speed if there is a bulb failure.
At least, that's how it was explained to me.
Post #140341 10th Sep 2012 6:37am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
You should also find the suspension is locked in normal height, the 'manual' indication light comes on and you cannot adjust the suspension.
Ian
Post #140343 10th Sep 2012 7:11am
+1 thats my understanding too...
Craig Thumbs Up
Post #140350 10th Sep 2012 8:02am
Andy
I'm currently towing the caravan across Ireland and I have no warning light on my dash. Can't say I've ever seen one 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #140378 10th Sep 2012 9:30am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Got no warning light (05 facelift) however if I remove an indicator lamp on the van I get a warning message. Pluggging the van in also disables the ride height ajuustment and reversing sensors.
There was along thread about this about sox months ago might be worth a search Mine was a blue one! Smile
Post #140379 10th Sep 2012 9:58am
05(facelift with MOST) mine stays on all the time towing the van or a trailer with a board connected Smile
mine does allow me to change height when connected.
Makes hitching up easier as well Thumbs Up FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #140386 10th Sep 2012 11:30am
RCusden
Wales
Get no warning light with mine either as stated will lock the suspension but only if it is in standard height ( when it's in motorway height it will stay that way until it raises it self as normal then will lock the suspension) but I do get the check trailer light warning on the dash when ever I'm towing and turn the engine off but all lights are ok
Roger
Post #140390 10th Sep 2012 12:20pm
Googsy
Dont be hogging the roads Noddy ! Laughing Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #140399 10th Sep 2012 12:57pm
Andy3681
I think it depends on if its an intergrated one or just one fitted with good old scotchlocks as to what effect it has on the car.
Thumbs Up Mine was a blue one! Smile
Post #140426 10th Sep 2012 3:20pm
