Home > Technical (L322) > td6 injector
spanner
td6 injector
Has anyone removed the injectors is it easy and do you need to remove the inlet manifold im getting fault P0134 cylinder inbalance anyone know what this means other than an injector
Thanks in advance
Post #140472 10th Sep 2012 5:07pm
Johnte
I took mine out to get them checked because I had a missfire (2 needed to be refurbished) Inlet manifold does need to be removed, but it's a simple straight forward job Thumbs Up
My injectors came out easy, but I believe that isn't always the case ... and can sometimes be VERY tight
Big Cry Big Cry
Post #140474 10th Sep 2012 5:22pm
spanner
Thanks for that do they come out with the inlet maifold or are they still in the head when the manifold is removed sorry for the questions but trying to build my self up to the task Sad
Post #140480 10th Sep 2012 5:44pm
Johnte
As far as I can remember (It was a long time ago) The injectors are in the head, but I don't think it's possible to remove them with the inlet manifold in place.
Post #140487 10th Sep 2012 6:27pm
