Home > General > 2009/2010 europe dvd satnav disc
Page 2 of 4 <1234>
RREIRE
Ireland 2007 Range Rover Vogue SE TDV8 Java Black
dan_uk_1984 wrote:
Was it BMWnavi.co.uk?
Mine arrived the other day, I haven't updated it yet, but it looks good.
Hi Dan, Would this system work on my pre face lift 05 vogue?
Post #13922 26th Feb 2010 12:13am
daveo
hi, looks like there not a prob to talk about sat nav disc, remember if your car is pre 05 you will have a mk3 ...cd based and not the mk4 dvd unit, so the upgrade will not work nor will the map.. i have v3.2 with the landrover logo and 2009 map, works 100% dvd, i am doing a new splash for my FFRR .
If you buy an upgrade disc for the mk3 cd unit make sure you have a good product key as it will ask you for this after the update is complete and i have heard that you can lock your unit up if you dont have it...
THESE ARE THE TWO SPLASH SCREENS I HAVE
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #13924 26th Feb 2010 12:33am
Still confused re my bog standard 2007 Sat Nav:
1: Is there a firmware update iand if so by Dealer or Purchased DVD?
2. Is there a Maps update and if so can I just get the latest available for 2009/10?
Post #13930 26th Feb 2010 8:36am
SAppie
nav
1. Yes, the firmware update is on the Map disc, just insert it and it will prompt you to upgrade... or you can go to the hidden menu ( hold your finger next to the nav screen at top for about 5 seconds, a number pad pops up, then input the code 134679, and the menu pops up...in here you can check the version, and force an upgrade.) Remember that the upgrades are on each and every nav dvd, so the latest 09/10 has the latest release. My car is the 2007 MY, and had a really old version of software, the new one improved it a lot, such as when you first click on "agree" , it now auto prompts for a destination..... and it now has the ability to "cancel guidance" on the first menu without having to go through loads to find it. there are other bits and pieces, and appears faster. Also obviously the new updated maps.
2. I "PM"-ed you last night.......
Enjoy.
Post #13932 26th Feb 2010 8:56am
dan_uk_1984
Is there anyone left who hasn't done this upgrade!?
The Speed camera warnings are great as are the LPG POI, my previous version had that too.
I'm going to do the S/W upgrade this weekend, and will report back.
Post #13937 26th Feb 2010 9:48am
Daveo,
How do you change the Splash Screens? Is it just a case of re-burning the DVD and replacing one of the files in the directories? I like those ones of yours, the black background makes them look very smart.
An all black screen with silver RANGE ROVER in the centre in the right font would look nice.
Did you create them yourself in a paint programme. Please let me know what the pixel dimensions etc are, would love to do this myself. Thumbs Up Bow down Discovery 4 HSE
1993 90 Tdi
Post #13940 26th Feb 2010 10:14am
Alias
Switzerland
If somebody changed it I am ready to buy it. Wink
Is it also available for the MY2007?
Post #13945 26th Feb 2010 10:58am
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
+1 to Alias and RRUK's posts Thumbs Up
What do we need to do? Via PM of course Wink
Post #13978 26th Feb 2010 9:31pm
daveo
NavTweak and NavSpeak it's a programs intended to change various things in 'navboot' and sound files.
you must have a current copy of the latest version v3.2 software
you will need the following programs
NavTweak 2.6 (49 KB):
http://rapidshare.com/files/8925524/navtweak.zip.html
NavSpeak 1.0 (23 KB):
http://rapidshare.com/files/8925664/navspeak.zip.html
Both programs requires the GTK+/Win32 Runtime Environment (5.2 MB):
http://gladewin32.sourceforge.net
Make sure it follows these guidelines:
Width: 400
Height: 234
Bit Depth: 8
Resolution: 96 x 96
Frames: 1
YOUR SPLASH SCREEN WILL BE LOCATED HERE.........
It should be located at the following path:
V_2 > RR > 0101 > BMWC01S > app_sw > navboot
select the navboot file and drag it to your desktop
The program will extract it and make a copy on your desktop
Open up navtwweak, clic on file go to V_2 > RR > 0101 > BMWC01S > app_sw > navboot..rombitmaps
you will see your splash screen there, click on it and right click, replace
after you have replaced the ,copy it back to your navboot,
then you have to right it to disc,
this is where i have failed a few times and i ave put it down to speed, use as slow as possible to wright the disc
I use Photoshop CS3 but you can use any image editor that allows you to create an image with the following parameters:
Image size
Image resolution
GIF image export
Bit Depth
Install UltraISO , most people use this to right the disc V8 facelift Range Rover Autobiography 22" wheels.
Post #13983 26th Feb 2010 9:50pm
daveo
hi dan, still messing around with the map disc, do you have both cameras and lpg stations on the same disc, and in the nav menu if your running v3.2 should give you the option to turn on/off the cameras, does it give you the option on the lpg stations .
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #14071 28th Feb 2010 11:13pm
Alias
Switzerland
Width: 400
Height: 234
Bit Depth: 8
Resolution: 96 x 96
Frames: 1
Image size
Image resolution
GIF image export
Bit Depth
Is it also possible to buy the DVD? I've never seen Speed Camera POI in the normal Navigation Disc.
Post #14100 1st Mar 2010 2:22pm
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
Hi I have had my new Copy/Clone Whistle Whistle Whistle Thumbs Up disc in my 2005 touch screen for over a week now and is great never been asked for any product key at all well happy Very Happy Mr. Green
Post #14204 2nd Mar 2010 9:18pm
daveo
hi simon, you wont be asked.. it was the early unit that asked for the code..you will be fine. V8 facelift Range Rover Autobiography 22" wheels.
Post #14208 2nd Mar 2010 9:40pm
daveo
hi alias, i have the map with the speed cameras but they are for the uk..so no good to you. V8 facelift Range Rover Autobiography 22" wheels.
Post #14209 2nd Mar 2010 9:42pm
dubbs
United Kingdom 2007 Range Rover Vogue SE Supercharged Buckingham Blue
Does this also give perspective view? Loved that on the M6 and would love to upgrade the 2007 version I have on the SC to 2009
Would someone be kind enough to PM me; I've got a MAC so would be great to find one already done so I just need to pop it in - Beer tokens would be plentiful Wink
Post #14329 4th Mar 2010 9:23pm
Page 2 of 4 <1234>
