Home > Technical (L322) > hdc and now something completly different
Rockportpurple
2002 Range Rover Vogue 4.4 V8 Giverny Green
ok guys hdc inoperative,new battery fitted today no issues there anymore new gearbox inhibitor switch fitted as only giving me 1,2,3,gear breather pipe split above gearbox,recon box fitted in 2010 only done 5800 miles fluid flushed changed etc,car runs great then on the way home from the garage 21miles ping no mesg but back to only 1,2,3 gears and in auto mode the same,,switch to sport mode ask it for fourth just jumps back to third and no more gears so a little annoying now after 3trips to the garage today no faults on the diag anyone else can shed some light on this what else it could be?
regards
clive
Post #141176 14th Sep 2012 9:42pm
Rockportpurple
we heres the update turns out it was the link from the battery to the bolt on the bulkhead that was loose resulting in error messages and hdc faults and everthing else took it back to the garage this morn diag with all the faults checked electrical tightness and that was at fault thankgod ive got my range rover back looking forward to driving it now
regards
clive
Post #141241 15th Sep 2012 12:06pm
RCusden
Wales
I'll have to check mine as I get the hdc inactive on start up every couple of days or when ever it feels like it cheers for the heads up
Roger
Post #141246 15th Sep 2012 12:22pm
Rockportpurple
hi roger i have been out and checked the car all afternoon and no hdc at all so seems to have cured it suppose time will tell but my hdc inactive was on everytime i turned the key then that led up to abs light,yellow triangle,hdc air suspension part of a failing battery it was as though the car was telling me it was poorly in a way try the connections were it meets the bulkhead where you can connect the jump leads etc thats were mine was loose hope this helps let me know how you get on
regards
clive
Post #141291 15th Sep 2012 6:11pm
