![]() | Home > Technical (L322) > Steering Question |
Britishlion Member Since: 04 Aug 2012 Location: Cheshire Posts: 93 ![]() ![]() ![]() |
Pedrochellie Member Since: 23 Feb 2012 Location: Surrey Posts: 82 ![]() ![]() ![]() |
Doesn't look like anyone knows anything, at least not today Britishlion!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35677 ![]() ![]() |
you might be thinking of the servotronic valve which regulates the pressure of the steering fluid..the most common sympton of this valves failure is heavy steering when de-accelarating because the faulty valve can't keep up with change in speed..it might be your problem and is very easy to change...do a search for more info.. ... - .- -.
Thanks Stan,
the best way I have found is to encompass the word/sentance with double quotation marks, ie "steering" ..this fococuses the search.. ... - .- -.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Remaining fococused ( |
Thanks Stan and Joe!
pedro, try revving the engine [out of gear] before you manoeuvre to get the steering fluid circulating properly, then try reversing/turning..if at this point you dont get the judder then its the servotronic valve, if indeed you do still get the judder then its something else.. ... - .- -.
Do you get a sense of which side of the car it is coming from or is it general?
sorry tim, 'very easy' it was for me.. |
Thank again Guys |
@ £600 plus fitting ?? (so probably double at main stealer !!) .
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Stratstones quoted me £1800 for a new steering rack ! Turned out the fault had nothing to do with the rack, just a bolt that could have been tighter on a suspension arm. Previously..
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
My '02 also does this and has been for some time.
