![]() | Home > Technical (L322) > Timed climate |
Allan Member Since: 15 Aug 2012 Location: Yorkshire Posts: 46 ![]() ![]() ![]() |
Just a low vehicle battery, take it out for a run.
Ukdave104 Member Since: 26 Apr 2012 Location: Aberdeen Posts: 116 ![]() ![]() ![]() |
Thanks for that Allan, I'm guessing then that the daily commute to work of 5 miles each way isn't enough to keep the battery topped up |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
re the charger, a few members have got solar powered ones from maplins .. ... - .- -.
Without running out to the car to grab the manual, which ciggie socket is still live when the ignition is switched off and the car locked |
The one in the boot is always live.
Thanks guy's, appreciate it |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Hi Dave... Read this thread for info on my solar charger. It recommends unplugging it before you start the car incase surges damage the circuitry.
Have you had the agm battery fitted and the updates to the system to reduce the max runtime to 17mins?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
I was actually joking about the solar powered parcel shelf but I see you have actually done it...!
Oooo, good question, didn't know about that, was there a recall for it or was it just a bulletin ![]() 2011 Range Rover Vogue 4.4 TDV8, Mine........ALL mine. 2012 Freelander 2 HSE SD4 - Mrs UkDave's new toy 2007 Freelander 2 GS TD4 - gone 2010 Discovery 4 XS - gone 2008 Discovery 3 HSE - gone 2007 Freelander 2 GS TD4 - gone |
Interesting, but it looks rather large ![]() 2011 Range Rover Vogue 4.4 TDV8, Mine........ALL mine. 2012 Freelander 2 HSE SD4 - Mrs UkDave's new toy 2007 Freelander 2 GS TD4 - gone 2010 Discovery 4 XS - gone 2008 Discovery 3 HSE - gone 2007 Freelander 2 GS TD4 - gone |
Ask your dealer as there was a long drawn out fight for people to get it fixed last year and they just gave up and fitted a better battery and reduced the run time. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 745 ![]() ![]() ![]() |
Your vehicle should have an AGM gel battery fitted, pop the hood and take a look it should be marked AGM. There was also an associated software update to go with the battery but it depends on when yours left the factory. I had one of the first 2011's to leave the factory (Jan 2011 build) and that’s when the low battery messages started appearing. I can't remember exactly when they started to fit AGM's as standard from the factory but I think it was from around June 11. Mine was swapped as part of a recall and has been fine since the battery swap |
Just checked tha battery, it's a VARTA that's fitted so it looks like the original battery is still on there.
