Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 14 of 49 <123 ... 131415 ... 474849>
spanner
Will this unit enable the park heat function ?
Post #142590 23rd Sep 2012 3:39pm
if you have the actual fbh , then yes.. ... - .- -.
Post #142591 23rd Sep 2012 3:49pm
spanner
Hi yes I have the FBH but whan I looked at the IIDT web site in the function list its green for reset faults etc but yellow for software manipulation
Post #142595 23rd Sep 2012 4:09pm
it'll be best to wait for steve/pat to answer this one...can you update your car profile so they/we know what range you have .. ... - .- -.
Post #142596 23rd Sep 2012 4:13pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
You can switch it on and off using the tool.
Post #142598 23rd Sep 2012 4:57pm
SteveMFr
Site Sponsor
Exactly. Thanks, Paul.
The instrument cluster will need a reboot to show the change in the timed climate menu. Earlier cars could do a 'reset' via the 'secret menu' in th cluster (google), but it is just as easy to do a short batt disconnect (follow RR battery disconnect / reconnect procedures!).
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #142669 24th Sep 2012 10:11am
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi Guys
The confusion comes from the fact that the Park Heating function is not activated via the FBH ECU. On the functionality table of the website, you will find, under the configuration column:
On 2002-2004 Range Rover, in the following ECU's
-IP instrument pack (Park Heating, Park Ventilation. Both must be set to Yes)
-ATC heat cool (Aux Heating, Park Heating. Both must be set to Yes)
On 2005 and up Range Rover
-ACM audio system (Aux Heating, Park Heating. Both must be set to Yes)
Cheers!
Post #143016 25th Sep 2012 5:10pm
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
Why does FMH not work for me? I have FMH enabled using fog lights and position lights, with a 40 second delay (which I presume is the length of time the lights stay on). But the lights never come on. I keep the light switch on the dash set to auto - does that have anything to do with it?
Can anyone from GAP give me the correct sequence to enable FMH please? (The nights are drawing in you know! Mr. Green )
Post #143025 25th Sep 2012 7:11pm
do you 'flash' the main beams before you leave the range... ... - .- -.
Post #143027 25th Sep 2012 7:13pm
daveo
my lights have to be on when i switch the car off,then when i switch of the lights they stay on for around 40s even after locking the car.
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #143038 25th Sep 2012 7:58pm
05 onwards you need to turn off engine then flash your main beam to turn on FMH
Craig Thumbs Up
Post #143052 25th Sep 2012 8:29pm
nubbin
Oh, I didn't know about having to flash main beam! Thanks for the heads up - I'll try that later. Very Happy
Post #143111 26th Sep 2012 10:02am
spanner
Where is the best place to purchase this unit considering daveo troubles ?
Post #143365 27th Sep 2012 5:24pm
Got mine from LRPARTS online quickly and for a good price. Others have done better still. Check out this thread page 11 on...
http://www.fullfatrr.com/forum/topic7073.h...;start=150 Mike - MPx
Post #143368 27th Sep 2012 6:15pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Got mine through Len - salop4x4@gmail.com Very easy to deal with, and very promp in replying to emails, and posting unit out. Thumbs Up Good price too - under half what Britpart here in Aus wanted for it.
Post #143859 1st Oct 2012 6:21am
