![]() | Home > Technical (L322) > how to work residual heat function |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
Have you tried looking in the manual? |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
yep.
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
I think the vehicle needs to be at normal running temperature i.e it should work after the cars has warmed up fully hope this helps but i could be wrong onto no6 Range Rover
i have tried the function after the engine has been on a 30 minute trip..fully warm..
I just used the timed climate on manual for that |
Residual heat is one of those items with... personality.
My TD6 did it easily but my Supercharged doesn't which is annoying when you consider just how much hear these |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
I used it once, for a couple minutes.
i think i have worked it out..
Many of us have asked the same question many times, there's so much stuff in the L322 that needs the battery that things like residual heat and FBH just kill off an already struggling unit. Probably just when you need it! Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3250 ![]() ![]() ![]() |
I've got a back up battery hooked up in the rear where the removable tow bar normally goes. Seems to do the trick |
Hi Jim! D'you mean 'Park Heat' - together on the display with timed ventilation? You can activate this with the IIDTool and it will show on the display, but as you do not have a diesel you won't have an FBH. They were an option with the petrol engined cars in Europe. I still don't understand why they never caught on in the US. Great stuff. I could send you one... Cost is about a grand for the kit and 2 days of install w/o prior experience. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
