Home > Technical (L322) > Ipod in Aux
Neil E
2019 Range Rover 2.0 PHEV Mariana Black
Ipod in Aux
I`ve just bought a lead from Maplins that`s a 3.5mm jack to red and white phono. Plugged it into the Aux in rear and set it up on the touchscreen at the front via Aux selection. Result = no sound!
I must be doing something wrong or the Aux input isn`t working.
Can anyone point me in the right direction so I can play my Ipod/Iphone through the speakers.
Thanks
Neil MY21 P400e AB
MY10 3.6 TD V8 Autobiography
55 Vogue se
Post #14331 4th Mar 2010 9:48pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Me thinks the Yellow phono socket is for sound, so you will need a cable with 3 phonos on the end.
If it is just sound, get alead and plug it in the Aux socket
Post #14333 4th Mar 2010 9:56pm
Neil E
I`ll try it but I`ve always thought Yellow was for composite/video.
Do you mean try the socket to the right of the coloured sockets which is just labelled AUX? It looks like a jack input??
Neil MY21 P400e AB
55 Vogue se
Post #14334 4th Mar 2010 10:12pm
nbunney
That's the one. Alot easyier, just 3.5mm jack to 3.5mm jack I think required.
Yes you're right yellow is for vid.
Post #14335 4th Mar 2010 10:22pm
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
http://cgi.ebay.at/ws/eBayISAPI.dll?ViewIt...K:MEWAX:IT XJC, RRV8, Series1 86 and 107% of real pleasure
Post #14365 5th Mar 2010 6:35pm
Neil E
Tried the 3.5mm jack into the aux socket today. It worked but sound only comes out of centre front speaker which sounds c**p.
That aux lead from ebay looks interesting.
Delsilencio, have you bought the lead and does it make all the speakers work?
Neil MY21 P400e AB
55 Vogue se
Post #14373 5th Mar 2010 7:39pm
delsilencio
http://www.xoutpost.com/stereo/9470-aux-in...tereo.html XJC, RRV8, Series1 86 and 107% of real pleasure
Post #14391 5th Mar 2010 10:53pm
elbitrevnoc
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
Neil, don't know where you are with this now, but I've just picked up my 2006 TD6 today and tried the ipod in the Aux (3.5 jack). All works well and sounds good, so it seems your problem may be a fault of some sort. Obviously you still have to control song selection from the ipod with this method, but it works fine through all speakers.
Hope you get it sorted.
Post #15134 19th Mar 2010 3:39pm
I use the Aux socket 3.5 jack to jack to play my Ipod, Blackberry and ITouch through the Logic7 system with pretty good sound quality and Volume on my TDV8.
Post #15138 19th Mar 2010 4:56pm
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
hi
i have just bought an 08 vogue with the ipod thru the aux jack
sounded horrid also had to change trcks thru the ipod which was in the glovebox..
hunters guilford have just fitted for me the official landrover ipox/mp3 kit
you plug the ipod into a lead in the bottom glovebox
put the head unit into cd and the 5 icons come up as mp3
you can the control everything on the ipod thru the headunit and steering wheel controls
also sound superb and doesn't invalidate your warranty
best of luck
this is the most cost effective solution to get the ipod to work efficiently
oh, i forgot,,, it also charges the ipod
Post #15140 19th Mar 2010 5:21pm
iancollins wrote:
hi
best of luck
How much?
Post #15141 19th Mar 2010 5:23pm
alexbartman
2007 Range Rover Vogue SE TDV8 Java Black
my dealer hadn;t even heard of it!! Then when I showed them (its on the official LR website) they quoted £200 for the kit and 3 hours to fit!!
"Ha" I said- found one on fleabay for £150 and fitted it myself - not the easiest job - but not too bad - took me 1.5 hours - and I'm a novice!! All the stage by stage instructions (witgh pics) come with it (and are also on the LR Owners website- and now its fitted it is really great and a massive improvement on the aux in solution which was quite awkward IMHO...
Post #15155 19th Mar 2010 6:59pm
sounds great but do you have a part number or kit name?
Post #15156 19th Mar 2010 7:01pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
I think the correct part number is LR004806 and its for 2007 - 2009.
200 sounds like a good price, I think they are normally closer to 240 Thumbs Up
Post #15157 19th Mar 2010 7:12pm
Whats involved in the fitting?
Seen one here for £256.00
http://www.brit-car.co.uk/product.php?xProd=98115&xSec=5497
Post #15160 19th Mar 2010 7:50pm
