![]() | Home > Technical (L322) > TD6 battery drain located!! (fuse numbers enclosed) - HELP! |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Bcu, Body Control Unit. One of the numerous ECU's on the car that controls all the bits. |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Hallo, I had the same problems years ago, my 2002 has no NAV, only Radio. First buyd the official cable to change under the panel with the new relais: NOTHING, then buyd the (in german IGEL), the part for the blower under the panel: NOTHING, then changed the original telefon connections from Nokia, and look: the battery is empty after 4 weeks, not after 4 days. What is about the alarm-system and the possibility to change the blowercable from always plus to ignition plus? Regards from germany, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
